Kenminehan
Diy Pipe Shelves
The joints are pre-cast.
You can get from hardware shop in industrial park (for galvanized or non-galvanized). Try AMK industrial park (or any industrial park). Just tell them you want water pipe joint (eg: 1/2", 90 degree elbow MM or MF; 1/2" = nominal diameter, 90 degree = 90 degree, MM = male male, MF = male female).
The straight section you will need to order. The shop will cut to the length you want and thread the ends for you.
After assembly, you will need to paint them to get a even color. The pipe & elbows you buy will not be same color tone.
There is of course the stainless material but is very ex...
Good luck.
