Aosbath
Energy Efficient Digital & Electric Storage Water Heaters Singapore - Sole Distributor of A.O. Smith
AOS-Top-Heater-in-America-e1444644236788
Blue-Diamond-Technology-e1444645017899.j
In Singapore and certain parts of Asia, water heaters we have been using for the last three decades have seen almost no technological improvement. In Europe and other more environmentally conscious countries, home owners have access to the latest energy saving technologies. Home owners can save from over $200 to $1000+ a year if they choose the right heater.
At AOS Bath, we are water heating specialists that believe in empowering homeowners with knowledge and choice. We are also the first company in Singapore to bring in cutting edge water heater technology to Singapore so you are no longer limited to obsolete choices.
A. O. Smith Corporation deals with gas, electric, instant, solar and heat pump water heaters. We provide accurate and unbiased information on all types of heaters.
AOS Bath Pte Ltd
178 Paya Lebar Road, #05-10, Singapore 409030
T: 6842 0090
W: www.aosbath.com
E: sales@aosbath.com
FB: www.facebook.com/aosbath
Edited by Aosbath
Hello everyone :)
If you have any questions about water heaters, be they gas, storage, instant, solar or heat pumps, please feel free to let us know and we’ll do our best to help! Our objective is to give you unbiased advice about all types of heaters so you can find the most suitable one for your own home.
Water heaters are the second largest energy consumers at home so it is natural that many home owners have asked us for an energy (and money) saving solution. One of the most popular heating technologies right now is Digital Heating.
conventional-vs-digital-e1444716280258.j
What is Digital Heating?
Digital heaters look exactly the same as your regular tank storage water heater, except they come with a touch screen control panel which allows home owners full control of their heaters. This should be familiar with those who are into smart home technology.
actual-digital-control-panels-e144471795
Digital heaters can save you up to $200/year in electric bills because unlike the conventional on/off switch, digital panels come with temperature adjustment controls and other energy saving functions. More on these latest technologies soon!
Edited by Aosbath
(as promised) more about how digital heaters can make our life easier.
Storage heater users out there… You know how we turn our heaters on for 15 min before using it to ensure there is sufficient hot water for our shower? With digital heating, there is no need to do that anymore!
Digital heaters come with a temperature indicator which show you how much hot water is in your tank with a single glance.
Red = hot water
Yellow = warm water
Green = cool water
Sometimes, you don’t even have to wait. Jump right into the shower if you have at least 3 red bars of hot water.
This is just one way technology makes our lives simple and saves our precious time.
More about digital heaters here >> Digital water heaters
temperature-indication-digital-heaters-e
Edited by Aosbath
can your water heater be mounted vertically in the service yard?
Assuming a family size of 3 what size storage would you recommend?
Digital panel mounting is concealed type? How is the wires run if I'm not making false wall?
Hello! :) Tq for your inquiry!
1. Can water heater be mounted vertically in service yard?
- Yes. More info on vertical water heaters here >> Lowboy Electric Heater (made in USA) - but this is not digital.. digital needs to be installed horizontally or you can consider Square Digital which is smaller >> Square Digital Heater
The horizontal type cannot be mounted vertically.
- service yard installations are ok, but if you are staying BTO, it *might* cost you more. If you want we can see your job and give you a quote. (no obligations, no charges!)
2. Family size 3, recommendation
- 30 lit (low usage), 40 lit (high usage)
- more general info on sizing >> Sizing your water heater
3. Digital panel mounting can be concealed, but you need to install early before your tiling is up. here are examples of exposed and concealed installation. Most HDB is exposed.
Screen-Shot-2015-10-19-at-5.57.17-pm-e14
My service yard only has space for vertical mount due to the clothes hanger. For the panel ideally to be mounted-outside the bathroom instead of in the service yard but my switches are all already concealed so I will give it a miss as protruding will look ugly.
Can pm me the cost for the 25l square digital one?
On 10/19/2015 at 10:39 PM, Changbp said:
Done, just PMed u! The 25L square digital is also a good choice since your switches are all already concealed. This version you can also save $200/year. Sq digital comes with a remote control instead of a built-into-wall touch screen control panel.. which means no more drilling or wiring :)
Update as of June 2017: The 25 lit digital water heater has been discontinued. We have received quite a lot of user feedback that this model is too small and hence produces too little water for the average household in Singapore.
Edited by Aosbath
Here's how digital water heaters can save your time.
Digital heaters heat water with a special technology that gives you hot water faster without consuming more energy! This patented technology is called "Instant Heating" You can find out more about it at this link > Instant Heating Technology
digital-water-heaters-give-instant-hot-w
Only digital heaters combine all the benefits of storage water heaters and instant water heaters
Digital water heater benefits:
- Good water pressure
- High water temperature
- Get hot water fast
Edited by Aosbath
Do you have a large family? Or perhaps you have guests staying over? Digital heaters can prevent you from running out of hot water.
A sensor is connected to the outlet of every digital heater so they can detect a higher-than-usual hot water usage.
The smart heater will then produce up to two times more hot water for your usage!
This heating technology is also patented and is called "MAX heating", because it gives you the MAXimum amount of hot water possible.
Screen-Shot-2015-10-30-at-10.30.17-am.jp
Find out more about the MAX heating technology here >> MAX Heating
Do you always find yourself waiting for 15 min for your heater to heat up before you enter? Digital heaters have intelligent functions that can save you time and give you hot water immediately.
Some digital heaters come with built-in timer functions. What this means is that you can now program your heater to turn on automatically.
It is especially useful to be able to sleep in for those precious few minutes in the morning.
It is also great for those days when you get back home from work and want to take a relaxing hot shower immediately!
More about built in timers here >> Digital Built-in Timers
Screen-Shot-2015-11-04-at-5.53.14-pm-e14
Thinking about getting a gas heater but want to know the difference between a gas and electric water heater?
Because of the number of requests for a water heater comparison.. We've done a survey with feedback from several retailers and homeowners who are doing their reno so you can get a better idea.
This is the first in a series of comparisons that we are going to do :) click below to find out what people are saying!
Gas vs Electric Water Heaters in Singapore
Edited by Aosbath
Eastvale-Condominium-by-Capitaland-1997.
A. O. Smith heaters installed in Eastvale Condominium, Capitaland for about 18 years now
"I have used my AOS water heater at Eastvale Condo for about 18 years. It has served me and my family well. We only changed it recently and I will continue to use AOS heaters for its durability."
- Mr Tan Hock Kwee, East Vale Condominium @ Pasir Ris
Water-Heater-Warranty-Guide-Singapore.jp
So many people are touting 10 year warranties.. LIFETIME warranties and proclaiming their products can last forever.
Today, warranties are kind of like insurance policies. We never really know what we are buying right? Wrong.
We've collected the warranties of many water heater brands and gone through their fine print so you can figure out how to decipher them once and for all.
Read all about it here >> Compare Water Heater Warranties
Photo-19-11-15-11-13-42-AM-e144790303061
Edited by Aosbath
Large A. O. Smith energy saving heat pump water heaters installed at the Ministry of Environment Building at Scotts Road. Heat pumps are the most energy saving water heaters in Singapore and are widely used by hotels, serviced apartments and country clubs. Heat pumps are more energy saving than solar water heaters!
AOS-heat-pump-water-heater-ministry-of-eMinistry-of-Environment-building-AOS-Bat
Edited by Aosbath
Please send me some details and pricing on your electric storage water heater and digital water heater. 30l would suffices. Does your cost include installation ?
