Jadzia
Recommendation For Hammer Or Impact Dril For Concrete Wall
Hi all! I'm totally clueless about drilling holes in hdb wall. We just finished renk about a yr and the walls are still quite bare. Would like to put up some paintings to spruce up the place. Also need to install some more assesories in the bathroom as well as kitchen. Would appreciate if you guys can recommend me a drill that can drill concrete walls as well as into bathroom tiles. Thanks!
Basically there are 2 types of handheld drills in the market you may consider.
Power wise it can be direct plug, or use battery.
1. The one mainly used for tighten screws, can adjust strengths. When it adjusted to maximum, it can drill.
Please don’t expect much on this type, it’s mainly for screwing, power average 400w.
This is sufficient, especially for quick tighten and losing to change drill bit.
Just an example, not recommending any brand, or model etc.
2. The one has a switch, changing only from screwing and hammer drilling. power average 650w.
You can use this for screwing but not easy to control and screwed up. It’s good for drilling holes on concrete household.
