shibumi
What Can Be Used To Scrub/clean Varnished (Balcony) Decking?
Hi fellows, I'm using Heveatech decking on my balcony, & it's varnished with a few coats of wood varnish. I do some gardening in my balcony & soiled (literally :P ) water splashes on the decking every now & then. It stains the decking such that using plain water & melamine sponge (that common white "magic" sponge) doesn't really remove the muddy stains. I don't think I can use thinner/turpentine because I presume those solvents are meant to strip paint.
What may I use to clean varnished decking? Anybody care to share some experience?
This is what happened to the varnished surface of my (Heveatech) decking (the strip that's further away) after using the "magic" sponge & plain water to scrub the stains off:
