Alexesben 0 Report post Posted September 14, 2015 anyone experiencing water leak fr om drill hole on bottom of the window frame?my contractor was installing aluminum window grill. They were drilling hole to fix on the bracket on the original window frame causing water to leak from the hole.they told me it is normal and got to let it drain till finish which i could not accept as it will spoil the flooring as i not sure when it will finish draining the water.should i get them to seal it with silicon or get bsc to check. mine is new flat Share this post Link to post Share on other sites
chower 1 Report post Posted November 11, 2015 anyone experiencing water leak fr om drill hole on bottom of the window frame?my contractor was installing aluminum window grill. They were drilling hole to fix on the bracket on the original window frame causing water to leak from the hole.they told me it is normal and got to let it drain till finish which i could not accept as it will spoil the flooring as i not sure when it will finish draining the water.should i get them to seal it with silicon or get bsc to check. mine is new flat Hi there! can i know if managed to resolve the problem and how? As i'm facing the exact same problem now!! Do advise, thanks!! Share this post Link to post Share on other sites
lshihui 0 Report post Posted November 21, 2015 Hi, I am facing this problem too. Anyone can advise? Thanks. Share this post Link to post Share on other sites
