Ahyong81
4Rm Resale Hdb Flat - A Bachelor Man Cave (Theme - Minimalist)
thanks ahyong81 for sharing!!
i spoke to a few ID and they gave me the look when i asked if can change the WC and they said if u have alot of cash to spare then change.. no issue but if it leaks u have to bear the responsibilities.. i was like???!!! care to share which floor is your new place?thanks!
today i went to see the WC u mentioned on the wall mounted type.. it cost at least $1.2k? care to share where you got yours?
looking forward to seeing your new transformation..
http://www.renotalk.com/forum/topic/72503-the-sky-parlour-an-executive-maisonette-journey/
my 1st renovation journey
Hi Ahyong81,
regarding the changing position of the toilet bowl, one of the ID said it cannot be done as the position of '**** pipe' cannot be shifted. How is your side going to resolve that issue? Thanks!
Renovation Journal (Daily) - Day 17
Floor tiles for kitchen and both bathroom completed. The electrician also came down to run the trunking in preparation for the electrical wiring for the whole house.
Edited by Ahyong81
Renovation Journal (Daily) - Day 18
Today was suppose to the installation for the fiber termination point by Net Link Trust requested by Starhub and thus My ID only arrange for the additional tiles that are required for the flat and no other work, so as to facilitate the NLT people to do their job more conveniently.
However, some human error and assumption by NLT and SH, they change the order to a service activation and not installation... Hai.... But nevertheless, after making a lot a calls and even personally went down to SH on the next day, they agreed to fix the installation 4 days later. It will be a big issue if I cannot install the fiber termination point as this will cause the entire renovation project to come to an haul. Faint....
Edited by Ahyong81
Renovation Journal (Daily) - Day 19
Water piping has been run for the entire flat (hot and cold pipe), The Jovan 35l storage heater also installed in the common bathroom, The WC system installed as well.
Edited by Ahyong81
Renovation Journal (Daily) - Day 20
The electrician has run the entire electrical wiring for the whole flat :)
Below is the picture of how the WC has been relocated using the P-trap type of WC instead of the normal s-trap type wc.
Edited by Ahyong81
Renovation Journal (Daily) - Day 21
Finally the installation appointment for the NLT to install the fiber termination point. Today also have make arrangement for Air-con piping and trucking to be lay for the LG Aircool System 3 :)
Edited by Ahyong81
i brought my wc at somewhere in balastier, recommended by my ID. the WC only cost me about $650 as compared to the normal one which normally cost about 200-400 depends on the type. The one I got is the attached from the back of the WC (p-trap type) instead the normal type which connect downwards (s-trap type). Its a full standing one cause I don't like the suspend type as after some times, i think it will become loose. Dont need to go for those above 1k, have cheaper alternative :)
The piping wont have issue if the ID or contractor doing it is good. Even for HIP upgrading program, they also outsource to external contractor to change the piping, its all boil down to luck and chance. Hope that everything will be good after the renovation :)
thanks ahyong81! any pics to share on the WC? thanks alot! i did go to balestier too.. not sure if we are talking about the samething.. hehe
Renovation Journal (Daily) - Day 22
Some patching works as well as painting the big waste pipe in the master bathroom in preparation for the ceiling works and box up works.
After the painting, the pipe looks blend in with the entire color scheme of the master bathroom.
Edited by Ahyong81
Renovation Journal (Daily) - Day 23
The Starhub guys came today to run the network cable for the IP TV set top box. One for the master bedroom and one at the living room. The two point are FOC.
Edited by Ahyong81
Renovation Journal (Daily) - Day 24
Ceiling works begin today, material also arrived. Amazing how fast one man can do it for the entire house false ceiling.
Edited by Ahyong81
Renovation Journal (Daily) - Day 25
False ceiling works goes into the kitchen and patching up works for previous false ceiling works. Foundation lay for common room.
Edited by Ahyong81
Renovation Journal (Daily) - Day 26
More false ceiling works, box up most of the aircon trucking and also level the beam at the master bedroom by adding addition plaster board.
Edited by Ahyong81
