decazz
Unused Tiles
quick qn, for boxes of unused tiles after tiling works, can the contractor bring back to the supplier for return?
if yes, the returned money is it to be given back to me, or will it be his profit?
If you are talking about 'boxes of unused tiles', the contractor will return to the supplier & gets billed for the actual number used.
Whether he pass it to you or not is a different question.
Normally, the contractor will make an estimate of how much they will need and order it. There will be extra and the tile supplier will take back whatever is not used. Tiling is not so straight forward, sometimes the appearance of the grain, color tone, etc... may have too much different. So a good tiler will check this and shortlist (select) the tiles that he can use.
Shibumi is also correct, the contractor will (should) arrange for you to keep a couple of pieces of each type of tile. In the event that you need to do some replacement in the far future, you have a couple of pieces.
