jimmya
Is This Quote Cheap And Reasonable?
hi all,
got him to reno my house, nicely done up, not the cheapest nor most expensive prices.
will like to commend well o his work. thanks
  On 7/26/2015 at 6:05 AM, jimmya said:
Hi all,
I received this from my ID, is it reasonable? So far this is the lowest that i had got from 5 IDs.
Do advice.
Thanks
Construct 50mm kitchen base 11.5ft - $420
Construct fridge base - $150
Construct washing machine base - $150
Supply cement, material n labour to lay 600x600 Homogeneous tiles for living room - $3360
Supply cement, material n labour to lay 600x600 Homogeneous tiles for master bedroom room - $1800
Supply cement, material n labour to lay 600x600 Homogeneous tiles for bedroom 2 - $1180
Supply cement, material n labour to lay 600x600 Homogeneous tiles for bedroom 3 - $1100
Supply labour to install 1 gallon heater - $120
Supply labour to install kitchen sink & tap on existing point - $100
Supply labour & material to lay 2” conceal drainage PVC for kitchen sink and washing - F.O.C.
Design, Fabricate & Install est(11.5ft) Kitchen top cabinet in solid-ply finish with high grade EDL/LAMITAK laminate - $1495
c/w Blum Hinges
c/w Color polygon
- all doors in ABS Trimming
- 1 set of hydraulic hinge gas spring
- 1 set of sand blast glass panel
- 1 set of cultery tray
- 1 nos.of 2 tier dish drainer
- labour to install cooker hood & hob - F.O.C
Design, Fabricate & Install 8ft tv console - $1040
Design, Fabricate & Install 8ft Feature wall - $1600
Design, Fabricate & Install Full Height Shoe Cabinet - $850
Design, Fabricate & Install Full Height Sliding Wardrobe est 6ft - $1560
Supply Labor & Materials to construct LBOX **** area - $1120
Custom made & install 11.5ft Quartz - $1265
Fabricate & install Glass Casement door at kitchen Entrance - $550
Fabricate & Install Shower Screen casement door at master bathroom - $500
Fabricate & Install Shower Screen sliding door at common bathroom - $550
Painting of whole unit using Nippon Original Paint using 5 nos. Colors - $1250
- all internal wall with Nippon Vinilex 5000 paint
- ceiling using Nippon Maxtex white color paint
Corrugate Paper for Protecting Existing Flooring - $180
Whole house general cleaning - $200
Chemical Washing - $200
Total $22235.
Do advice and help me out.
thanks
Hi, Can share contact number and person in charge on above contractor. Thank u so much. Can email me at bernlin70@gmail.com.
  On 1/7/2017 at 12:25 PM, davetan said:
hi all,
Hi davetan, you're using the same contractor jimmya used? if so, can PM me the details? Thanks!
hi @jimmya can you pm me your ID contact please?
Thank you!
May I know if there are any hidden costs that were not included in the quote given to you?
Were you asked to top-up other than those you requested/changed?
