Rulzetta 0 Report post Posted October 8, 2016 Hi jimmya appreciate if u can pm me ur contact. Thanks Share this post Link to post Share on other sites
bambeeboom 0 Report post Posted October 12, 2016 Hi jimmya can send me the contact for reference? Thanks in advance! jasminebocksq@gmail.com Share this post Link to post Share on other sites
Dawntie 0 Report post Posted October 22, 2016 (edited) On 7/26/2015 at 6:05 AM, jimmya said: Hi all, I received this from my ID, is it reasonable? So far this is the lowest that i had got from 5 IDs. Do advice. Thanks Construct 50mm kitchen base 11.5ft - $420 Construct fridge base - $150 Construct washing machine base - $150 Supply cement, material n labour to lay 600x600 Homogeneous tiles for living room - $3360 Supply cement, material n labour to lay 600x600 Homogeneous tiles for master bedroom room - $1800 Supply cement, material n labour to lay 600x600 Homogeneous tiles for bedroom 2 - $1180 Supply cement, material n labour to lay 600x600 Homogeneous tiles for bedroom 3 - $1100 Supply labour to install 1 gallon heater - $120 Supply labour to install kitchen sink & tap on existing point - $100 Supply labour & material to lay 2” conceal drainage PVC for kitchen sink and washing - F.O.C. Design, Fabricate & Install est(11.5ft) Kitchen top cabinet in solid-ply finish with high grade EDL/LAMITAK laminate - $1495 Design, Fabricate & Install est(11.5ft) Kitchen top cabinet in solid-ply finish with high grade EDL/LAMITAK laminate - $1495 c/w Blum Hinges c/w Color polygon - all doors in ABS Trimming - 1 set of hydraulic hinge gas spring - 1 set of sand blast glass panel - 1 set of cultery tray - 1 nos.of 2 tier dish drainer - labour to install cooker hood & hob - F.O.C Design, Fabricate & Install 8ft tv console - $1040 Design, Fabricate & Install 8ft Feature wall - $1600Design, Fabricate & Install Full Height Shoe Cabinet - $850 Design, Fabricate & Install Full Height Sliding Wardrobe est 6ft - $1560 Supply Labor & Materials to construct LBOX **** area - $1120 Custom made & install 11.5ft Quartz - $1265 Fabricate & install Glass Casement door at kitchen Entrance - $550 Fabricate & Install Shower Screen casement door at master bathroom - $500 Fabricate & Install Shower Screen sliding door at common bathroom - $550 Painting of whole unit using Nippon Original Paint using 5 nos. Colors - $1250 - all internal wall with Nippon Vinilex 5000 paint - ceiling using Nippon Maxtex white color paint Corrugate Paper for Protecting Existing Flooring - $180 Whole house general cleaning - $200 Chemical Washing - $200 Total $22235. Do advice and help me out. thanks Hi, came across your post. Mind if you share with me ur ID contact please? TIA! Edited October 24, 2016 by Dawntie Share this post Link to post Share on other sites
Stlf84 0 Report post Posted October 24, 2016 Hi jimmya, can send me the contact for reference? Thanks in advance! Stlf84@gmail.com Share this post Link to post Share on other sites
Calebcaleb 0 Report post Posted October 24, 2016 Share a contact Share this post Link to post Share on other sites
elimcs 0 Report post Posted October 25, 2016 Hi Jimmya, Can you pm share your ID contact. Thanks. Share this post Link to post Share on other sites
Joey12345 0 Report post Posted October 25, 2016 On 7/26/2015 at 6:05 AM, jimmya said: Hi all, I received this from my ID, is it reasonable? So far this is the lowest that i had got from 5 IDs. Do advice. Thanks Construct 50mm kitchen base 11.5ft - $420 Construct fridge base - $150 Construct washing machine base - $150 Supply cement, material n labour to lay 600x600 Homogeneous tiles for living room - $3360 Supply cement, material n labour to lay 600x600 Homogeneous tiles for master bedroom room - $1800 Supply cement, material n labour to lay 600x600 Homogeneous tiles for bedroom 2 - $1180 Supply cement, material n labour to lay 600x600 Homogeneous tiles for bedroom 3 - $1100 Supply labour to install 1 gallon heater - $120 Supply labour to install kitchen sink & tap on existing point - $100 Supply labour & material to lay 2” conceal drainage PVC for kitchen sink and washing - F.O.C. Design, Fabricate & Install est(11.5ft) Kitchen top cabinet in solid-ply finish with high grade EDL/LAMITAK laminate - $1495 Design, Fabricate & Install est(11.5ft) Kitchen top cabinet in solid-ply finish with high grade EDL/LAMITAK laminate - $1495 c/w Blum Hinges c/w Color polygon - all doors in ABS Trimming - 1 set of hydraulic hinge gas spring - 1 set of sand blast glass panel - 1 set of cultery tray - 1 nos.of 2 tier dish drainer - labour to install cooker hood & hob - F.O.C Design, Fabricate & Install 8ft tv console - $1040 Design, Fabricate & Install 8ft Feature wall - $1600Design, Fabricate & Install Full Height Shoe Cabinet - $850 Design, Fabricate & Install Full Height Sliding Wardrobe est 6ft - $1560 Supply Labor & Materials to construct LBOX **** area - $1120 Custom made & install 11.5ft Quartz - $1265 Fabricate & install Glass Casement door at kitchen Entrance - $550 Fabricate & Install Shower Screen casement door at master bathroom - $500 Fabricate & Install Shower Screen sliding door at common bathroom - $550 Painting of whole unit using Nippon Original Paint using 5 nos. Colors - $1250 - all internal wall with Nippon Vinilex 5000 paint - ceiling using Nippon Maxtex white color paint Corrugate Paper for Protecting Existing Flooring - $180 Whole house general cleaning - $200 Chemical Washing - $200 Total $22235. Do advice and help me out. thanks Hi can PM me your ID contact n firm ? Thanks Share this post Link to post Share on other sites
jjrenosoul 0 Report post Posted October 28, 2016 On 9/16/2015 at 1:49 AM, jimmya said: hi, pm u guys already. Can you pm ur I'd/contractor?TIA Share this post Link to post Share on other sites
shuantzelim 0 Report post Posted November 2, 2016 On 7/26/2015 at 6:05 AM, jimmya said: Hi all, I received this from my ID, is it reasonable? So far this is the lowest that i had got from 5 IDs. Do advice. Thanks Construct 50mm kitchen base 11.5ft - $420 Construct fridge base - $150 Construct washing machine base - $150 Supply cement, material n labour to lay 600x600 Homogeneous tiles for living room - $3360 Supply cement, material n labour to lay 600x600 Homogeneous tiles for master bedroom room - $1800 Supply cement, material n labour to lay 600x600 Homogeneous tiles for bedroom 2 - $1180 Supply cement, material n labour to lay 600x600 Homogeneous tiles for bedroom 3 - $1100 Supply labour to install 1 gallon heater - $120 Supply labour to install kitchen sink & tap on existing point - $100 Supply labour & material to lay 2” conceal drainage PVC for kitchen sink and washing - F.O.C. Design, Fabricate & Install est(11.5ft) Kitchen top cabinet in solid-ply finish with high grade EDL/LAMITAK laminate - $1495 Design, Fabricate & Install est(11.5ft) Kitchen top cabinet in solid-ply finish with high grade EDL/LAMITAK laminate - $1495 c/w Blum Hinges c/w Color polygon - all doors in ABS Trimming - 1 set of hydraulic hinge gas spring - 1 set of sand blast glass panel - 1 set of cultery tray - 1 nos.of 2 tier dish drainer - labour to install cooker hood & hob - F.O.C Design, Fabricate & Install 8ft tv console - $1040 Design, Fabricate & Install 8ft Feature wall - $1600Design, Fabricate & Install Full Height Shoe Cabinet - $850 Design, Fabricate & Install Full Height Sliding Wardrobe est 6ft - $1560 Supply Labor & Materials to construct LBOX **** area - $1120 Custom made & install 11.5ft Quartz - $1265 Fabricate & install Glass Casement door at kitchen Entrance - $550 Fabricate & Install Shower Screen casement door at master bathroom - $500 Fabricate & Install Shower Screen sliding door at common bathroom - $550 Painting of whole unit using Nippon Original Paint using 5 nos. Colors - $1250 - all internal wall with Nippon Vinilex 5000 paint - ceiling using Nippon Maxtex white color paint Corrugate Paper for Protecting Existing Flooring - $180 Whole house general cleaning - $200 Chemical Washing - $200 Total $22235. Do advice and help me out. thanks Hi jimmya, can PM me the contractor details? Thanks thanks! Share this post Link to post Share on other sites
Ernest Yong 0 Report post Posted November 20, 2016 Hi jimmy can pm me the contact? thanks! Share this post Link to post Share on other sites
versus 0 Report post Posted November 21, 2016 Hi Jimmya, Can you share with me the contact of your ID. Thanks in advance. Share this post Link to post Share on other sites
faceless 1 Report post Posted November 21, 2016 jimmy - kindly share your ID . thanks Share this post Link to post Share on other sites
seacube 0 Report post Posted December 11, 2016 Hi Jimmya, can share your ID contacts, thanks! Share this post Link to post Share on other sites
Cyw 1 Report post Posted December 11, 2016 Can pm contact? Thanks! Share this post Link to post Share on other sites
Zincman81 5 Report post Posted December 12, 2016 Hi jimmya, can u pm me your id contacts?thanks alot Share this post Link to post Share on other sites
