jimmya
Is This Quote Cheap And Reasonable?
Hi there
Can u pm me this ID pls.
Thanks
Hi all,
I received this from my ID, is it reasonable? So far this is the lowest that i had got from 5 IDs.
Do advice.
Thanks
Construct 50mm kitchen base 11.5ft - $420
Construct fridge base - $150
Construct washing machine base - $150
Supply cement, material n labour to lay 600x600 Homogeneous tiles for living room - $3360
Supply cement, material n labour to lay 600x600 Homogeneous tiles for master bedroom room - $1800
Supply cement, material n labour to lay 600x600 Homogeneous tiles for bedroom 2 - $1180
Supply cement, material n labour to lay 600x600 Homogeneous tiles for bedroom 3 - $1100
Supply labour to install 1 gallon heater - $120
Supply labour to install kitchen sink & tap on existing point - $100
Supply labour & material to lay 2” conceal drainage PVC for kitchen sink and washing - F.O.C.
Design, Fabricate & Install est(11.5ft) Kitchen top cabinet in solid-ply finish with high grade EDL/LAMITAK laminate - $1495
c/w Blum Hinges
c/w Color polygon
- all doors in ABS Trimming
- 1 set of hydraulic hinge gas spring
- 1 set of sand blast glass panel
- 1 set of cultery tray
- 1 nos.of 2 tier dish drainer
- labour to install cooker hood & hob - F.O.C
Design, Fabricate & Install 8ft tv console - $1040
Design, Fabricate & Install 8ft Feature wall - $1600Design, Fabricate & Install Full Height Shoe Cabinet - $850
Design, Fabricate & Install Full Height Sliding Wardrobe est 6ft - $1560
Supply Labor & Materials to construct LBOX **** area - $1120
Custom made & install 11.5ft Quartz - $1265
Fabricate & install Glass Casement door at kitchen Entrance - $550
Fabricate & Install Shower Screen casement door at master bathroom - $500
Fabricate & Install Shower Screen sliding door at common bathroom - $550
Painting of whole unit using Nippon Original Paint using 5 nos. Colors - $1250
- all internal wall with Nippon Vinilex 5000 paint
- ceiling using Nippon Maxtex white color paint
Corrugate Paper for Protecting Existing Flooring - $180
Whole house general cleaning - $200
Chemical Washing - $200
Total $22235.
Do advice and help me out.
thanks
Hi jimmya, how's renovation coming along for ur nice house, don't mind can share with me ur contractor contact? And also, how long before the contractor will come back with a quote?
hi gfkid,
so far so good, had done up my laminate floors and lightings andkitchen cabinet too.
will post some pictures tonite. was busy at work and rushing everything.
pm u guys already.
all d best!
So sorry was busy with work... laminate flooring up. but still have click clat sound, they says need time to stable.
well we shall see.
med_gallery_70346_8_48046.jpgmed_gallery_70346_8_58261.jpgmed_gallery_70346_8_34937.jpgmed_gallery_70346_8_90027.jpg
