jimmya
Is This Quote Cheap And Reasonable?
Hi all,
I received this from my ID, is it reasonable? So far this is the lowest that i had got from 5 IDs.
Do advice.
Thanks
Construct 50mm kitchen base 11.5ft - $420
Construct fridge base - $150
Construct washing machine base - $150
Supply cement, material n labour to lay 600x600 Homogeneous tiles for living room - $3360
Supply cement, material n labour to lay 600x600 Homogeneous tiles for master bedroom room - $1800
Supply cement, material n labour to lay 600x600 Homogeneous tiles for bedroom 2 - $1180
Supply cement, material n labour to lay 600x600 Homogeneous tiles for bedroom 3 - $1100
Supply labour to install 1 gallon heater - $120
Supply labour to install kitchen sink & tap on existing point - $100
Supply labour & material to lay 2” conceal drainage PVC for kitchen sink and washing - F.O.C.
Design, Fabricate & Install est(11.5ft) Kitchen top cabinet in solid-ply finish with high grade EDL/LAMITAK laminate - $1495
c/w Blum Hinges
c/w Color polygon
- all doors in ABS Trimming
- 1 set of hydraulic hinge gas spring
- 1 set of sand blast glass panel
- 1 set of cultery tray
- 1 nos.of 2 tier dish drainer
- labour to install cooker hood & hob - F.O.C
Design, Fabricate & Install 8ft tv console - $1040
Design, Fabricate & Install 8ft Feature wall - $1600
Design, Fabricate & Install Full Height Shoe Cabinet - $850
Design, Fabricate & Install Full Height Sliding Wardrobe est 6ft - $1560
Supply Labor & Materials to construct LBOX **** area - $1120
Custom made & install 11.5ft Quartz - $1265
Fabricate & install Glass Casement door at kitchen Entrance - $550
Fabricate & Install Shower Screen casement door at master bathroom - $500
Fabricate & Install Shower Screen sliding door at common bathroom - $550
Painting of whole unit using Nippon Original Paint using 5 nos. Colors - $1250
- all internal wall with Nippon Vinilex 5000 paint
- ceiling using Nippon Maxtex white color paint
Corrugate Paper for Protecting Existing Flooring - $180
Whole house general cleaning - $200
Chemical Washing - $200
Total $22235.
Do advice and help me out.
thanks
  • Like 1
Pretty good pricing from this particular id. However, just a note that if this quotation appears to be much lower than the other four ids, do a "safety" check like googling this id, searching on renotalk etc, to find other reviews on this id, where available. Cheers!
  • Like 1
hi pdark,
thanks for ur advice. so far i have check its still ok.
their coy is hdb registered reno contractor unlike alot of id firms who are not. they just sub out to ppl.
they have their own carpenters as well. maybe thats bcoz their price is on low side. i think coy is
around 15yrs so i think harder to run away or do a bad job for me.
the person is friendly n truthful to me on the things that i want. in fact he ask me to save costs rather than
other ids who says do this do that. so far i feel quite comfortable with him.
thanks man!
Glad to hear that! One more tip from me - the best way to check workmanship is to arrange a visit to one of the id's existing projects. Even better if the house owner is around when you visit. :good:
Can you PM me the contact of the ID and his company? Thank you very much in advance.
hi pdark,
thanks for ur advice. so far workmanship quite good. they have their own carpenters
thats y prices a bit cheaper i guess.. n they give 5 years warranty.
which a lot of id only give 1 or 2 years only.
thanks anyway
hi tarzanboy,
i tried to pm u the contacts but it cannot go through.
it says u cant receive any more messages.
fyi.
cheers
I find his price is too weird or they said they going to give Custom made & install 11.5ft Quartz - $1265 do you know Quartz is the most expensive among all the other stones how can be $1265 for 11.5ft is equal to $110 per ft i think they give solid surface rather than the real quartz because the market price is really too low.And there are some hidden cost behind it because i have been scam before.They tell me this that in the end give me lousy quality and most important Cheaps things don't come good and good thing don't come cheap.Now i know why some ID firm they charge me so high because of their skillful worker and good quality !
