maxj23
Split Type Aircon Usage Question
Hi all just wanted to ask, i have a system 4 aircon and btu capacity for outdoor unit is 28k btu. Indoor unit for living rm is 18k and 9k x3 for each bedroom. If i use 2 bedrooms 9k each + living rm 18k total use is 36k btu, will it cause damage or overload to the outdoor unit? Thanks
The compressor will on run at 28k btu only, no matter how you turn on to max.
From 9k x 2 for each room can feel very sufficient, once turn on another 9k for 3rd room still ok in normal cooling, but once turn on the living room would be insufficient to be made all room to be slower cooling performance until the living room while cooling sometime then for the rest smaller room will feel as normal again.
The design for 3 room only.
Meant switch on either 3x 9k or 2x 9 + 18k still works as sufficient cooling.
