bubblepearl
Is This Quotation Ok For An 5 Room - 121sq?
Hi, Could anyone help me see if this quotation ok?
My flat is a resale 5 room flat which i'll need many hacking.. :bow:
Thanks in advance to all! :)
NO Description Amount:
Promotional Package for kitchen and 2 nos of toilets - items 1 to 31 $11,888.00
Hacking Works
1 Hack existing kitchen wall and floor tiles
2 Hack/dismantle existing kitchen cabinet
3 Hack 2 nos of toilet wall and floor tiles
4 Dismantle/remove toilet WC , basin and fittings
Masonary Works
5 Supply and lay cement screeding for kitchen and 2 nos of toilet wall
6 Supply and lay ceramic wall tiles for kitchen and 2 nos of toilet ( Promotion Package
Material for wall tiles $2 )
7 Supply and lay cement screeding for kitchen and 2 nos of toilet floor
8 Supply and lay HDB approved water proofing membrane-K11 for kitchen floor
and 2 nos of toilet
9 Supply and lay heavy duty homogeneous floor tiles for kitchen and 2 nos of
toilet floor tiles and kitchen screeding only ( Promotion Package Material for floor
tiles $ 2.5 )
10 Supply and construct 1 nos of concrete cabinet base c/w side tiling works
11 Supply and construct concrete fridge and washing machine
base with full tiling work
Plumbing Works
12 Supply and install new copper piping for whole house
13 Supply and install outlet piping for sink and washing machine
14 Supply and install 1 nos of kitchen sink and sink tap
15 Supply and install 2 nos of dual flush system toilet bowl
Model:Saniton/HCG, Colour
16 Supply and install 2 nos of basin and 2 no.s basin tap
17 Supply labour to install 2 nos of bathroom accessories c/w mirror
Electrical Works
18 Supply labour to install back new 4 X lighting point,2 X double socket outlet,
2 X single socket outlet,1 X cooker hood point.1 X cooker hob point and
2 X heater point
Aluminium Works
19 Supply and install 2 nos of WPC aluminium frame c/w 2/4 acrylic panel toilet
bifold door
Carpentry Works
20 To design and fabricate L20ft laminates solid ply kitchen cabinet c/w laminated
casement door with ABS trimming,stainless steel handles,2nos.of frosted
glass and 1nos.of 2 tier stainless steel diskrack with drip tray
21 Supply and install L10ft solid surface work top at kitchen
Miscellaneous
22 Haulage fee:uploading of cement, sand, tiles and material and downloading of
debris
23 Provision of waste container lorry and disposal of debris to M.O.E approved
dumping ground
24 Supply of corrugated paper and plaster sheet for flooring protection
25 Chemical wash upon completion of works
26 HDB permit handling fee
FOC Item
27 Supply and install 2 nos of toilet accessories c/w mirror FOC
28 Supply and install 2 nos of instant heater FOC
29 Supply and install 2 nos of 2 way tap FOC
30 Supply and install 1 nos of washing machine tap FOC
31 Supply and install 1set of Hood and Hob FOC
Hacking Works
32 Hack existing floor tiles ****,dining hall,store room balcony and 3 nos of bedroom $800.00
33 Hack existing wall tiles at balcony $200.00
34 Hack/dismantle existing alum sliding door at balcony $80.00
35 Hack/dismantle simple cornices at whole house $200.00
Masonary Works
36 Supply and lay 600mm X 600mm homogenous floor tiles ****/dining hall,stroe room $4,200.00
and 3 nos of bedroom c/w skirting ( Material for floor tiles $2.8 )
37 Supply and lay heavy duty homogenous floor tiles at balcony $500.00
38 Supply labour to make good at balcony wall after hacking $250.00
39 Supply labour to make good at wall after dismantle sliding door at balcony $80.00
40 Supply and install stainless steel flat rubbish chute at kitchen $180.00
41 Supply and construct shower kerb at master toilet $80.00
Carpentry Works
42 Supply and install additional L12ft for kitchen cabinet $960.00
43 Supply and install additional L8.5ft solid surface work top at kitchen $595.00
44 To design and fabricate L10ft laminated sliding door wardrobe at master room $1,850.00
45 To design and fabricate L5ft laminates full height shoe rack at main entrance $900.00
46 To design and fabricate L4ft laminates full height divider at main entrance $600.00
Aluminium Works
47 Supply and install B.A or Sliver alum grill for whole house ( 218sgft ) $980.00
48 Supply and install B.A or sliver alum frames c/w tinted glass sliding window at balcony, $1,080.00
dining hall and kitchen ( 108sqft )
Temper Glass Works
49 Supply and install 10mm L-shape frameless shower screen at master toilet $450.00
Vanity Top Works
50 Supply and install L3ft solid surface vanity c/w top and bottom cabinet storage and $1,050.00
mirror in laminates finish at master toilet
Cornices Works
51 Supply and install false ceiling at main entrance and passage way $180.00
52 Supply and install L-Box light holder **** hall $330.00
53 Supply and install L-Box light holder at dining hall $250.00
54 Supply and install plaster board to box up bedroom door above louvres $50.00
Paint Works
55 Paint for whole unit all door,frames and all pipes(ICI or NIPPON emulsion paint) $1,000.00
56 Plastering for whole unit wall and ceiling $1,650.00
Electrical Works
57 D.B Box $250.00
58 22 nos of Lighting Point $416.00
59 22 nos of Fitting Light $160.00
60 5 nos of Single point $225.00
61 5 nos of Double Point $275.00
62 1 nos of Air-Com Point $90.00
63 4 nos of SCV TV Point $360.00
64 3 nos of Tel Point $150.00
65 1 nos of Fan Fitting $45.00
Total: $32,354.00
Hi Can you pass contractor details as I trying to find suitable contractor to do up my resale unit? Your help is greatly appreciated..
I PM both of u liao...for me..i got tight budget for reno so i need to keep everything within 30k...
Hi bubblepearl,
Can you PM me the contacts for your con/id?
Thanks..
My flat is a resale 5 room flat which i'll need many hacking.. :(
Thanks in advance to all! :sport-smiley-018:
Hacking Works
Masonary Works
and 2 nos of toilet
tiles $ 2.5 )
Plumbing Works
Electrical Works
2 X heater point
Aluminium Works
bifold door
Carpentry Works
Miscellaneous
debris
dumping ground
FOC Item
Hacking Works
Masonary Works
Carpentry Works
Aluminium Works
Temper Glass Works
Vanity Top Works
Cornices Works
Paint Works
Electrical Works
57 D.B Box $250.00
Total: $32,354.00
Hi, care to share ur contractor's company name and contact info?? Thanks!
ya can share ur ID/contractor as well?
Hi everyone,
I am new to this forum and have a suggestion.
Could bubblepearl or someone PM'd earlier just post the ID so there is no need for repeated requests? I am sure bubblepearl while doing all a favor will be tired by now, indirectly as a result of the ID ;)
Else can someone pm the by now famous ID contact.
Also, would be good if bubblepearl or anyone who used the ID share some of their experiences as the prove of the durian is in the eating.
Thanks
Hi bubblepearl,
I'm looking for an ID to renovate my resale 5rm as well.. size is similar @ 122sqm. Will you please share your ID contact?
thanks vm for your help.
Hacking Works
Masonary Works
and 2 nos of toilet
tiles $ 2.5 )
Plumbing Works
Electrical Works
2 X heater point
Aluminium Works
bifold door
Carpentry Works
Miscellaneous
debris
dumping ground
FOC Item
Hacking Works
Masonary Works
Carpentry Works
Aluminium Works
Temper Glass Works
Vanity Top Works
Cornices Works
Paint Works
Electrical Works
57 D.B Box $250.00
Total: $32,354.00
Hi Pal, is my 2 cents worth, do yr contractor or ID quote you for yr doors frames and doors? Well, can u pm me e electician, the quote for the wiring seems to be good. :dancingqueen:
Hi, can anyone pm me the contact of this contractor. Not sure whether it is late or not. Thanks
