duomaxwell
Llpl's New House @ Punggol Waterway Brooks
Hi duomaxwell
1. May I know how mch your ID charged you per feet of the 3 tracks sliding door wardrobe (including the mirror and colour PVC)
2. What is the hardware you used for the TV console sliding door? Excel or blum hardware? Any part no.
Thanks
  On 5/27/2016 at 1:32 AM, evangel said:
Do you have to top up for this paint? Usually is Vinilex 5000 right?
Hi evangel,
Nope. we don't have to top up for Odour-less easy wash. Our ID does not limit us on the selection of paint types, that's why we purposely chose the most expensive series. :lol:
Yup, you are right, usually I think others are only being offered Vinilex 5000, need to top up if using other range of paints if I am not wrong :P
  On 1/12/2016 at 6:42 AM, duomaxwell said:
Hi Lazyfatcat, thanks for dropping. I'm sorry to hear that. guess the ID really "stepped" onto you big time. But at least he willing to redo the cabinets. :rolleyes:
Day 15 (11th Jan 2016) (Painting)
Painter brought all the materials to prepare for the painting of the whole house.
Realised that not all the paint cans are Odour Less Easy Wash (some are Vinilex 500, some are just easy wash or Odour-less, ID immediately called the painter and requested him to change. "thumbs up to the ID"
Wrong Paint type
Correct Paint Type
I count ourselves lucky that we fixed an appointment with the glass contractor to discuss on the approach for the master bedroom toilet (whether to install a sliding glass door or a normal glass door for shower area) today before the painter starts work, if not the painter would have started painting with the wrong paint type.
Painting will continue tomorrow (12th Jan) and on Wednesday (13th Jan).
The following are the final line by line description of our renovation works for reference :)
S/n
A Living/Dining/Bedroom 4
1 To design & construct false ceiling w/ cove lighting effect
2 To design & construct est. L 12.5ft full ht partition wall using gypsum board
3 To supply & install normal wooden door frame
4 To design & construct est L 8.5ft suspended Tv console using solid-ply laimate c/w internal polyester
5 To supply & install semi solid veneer door w/lever handle & hinges
6 To design & construct est L 3ft full ht display cabinet using solid-ply laminate c/w glass door (max 10pcs glass shelving)
7 To design & construct est L 6.5ft full ht cabinet using solid-ply laminate c/w partial open shelve
8 To design & construct est L 3.5ft full ht feature wall using solid-ply wooden frame open shelve (FOC upgraded)
9 To design & construct est L 5.5f settee bench w/storage using solid-ply laminate
10 To design & construct est L 5.5f half ht backing using solid-ply laminate (Ht 750mm)
11 To design & construct est L 5.5ft craftstone on top settee backing c/w chalkboard paint (labour to lay craftstone only)
12 To design & construct L 8.5ft full ht Tv feature wall using solid-ply laminate boarder (labour to lay craftstone only)
13 To design & construct est L 6.5ft craftstone on full partition wall (labour to lay craftstone only)
14 To supply labour to install skirting
B Kitchen / Service Yard
1 To supply labour to hack est L 8ft full ht existing wall (Subject to HDB Approval)
2 To supply labour to dismantle existing folding door, window & hack est L 4ft half ht existing wall
3 To supply labour to make good damaged area (plaster smooth wall - FOC)
4 To design & construct est L 7.5ft half ht parition wall with wood support using gypsum board (sliding door)
5 To supply & construct kitchen cabinet base & washing machine base
6 To design & construct est L 11ft top & 14.5ft btm kitchen cabinet using solid-ply laminate
7 To design & construct est L 4.5ft full ht cabinet using solid-ply laminate c/w internal polyester
8 To supply & install est L 14.5ft kompacplus work top on top of kitchen cabinet
9 To supply & install est L 7.5ft kompacplus backing in between top & btm kitchen cabinet
10 To supply & install est L 7.5ft kompacplus backing on top of kitchen cabinet (est H  1700mm)
11 To supply &  install est L 4ft half ht fixed clear glass panel using 10mm thick tempered glass
12 To supply & install 10mm thick tempered sliding glass door
13 To design & construct est L 7.5ft bar counter using solid-ply laminate (Ht 1000mm) (2sided finishing)
14 To Supply & install est L 7.5ft kompacplus work top on top of bar counter
15 S1 x 4 units, S4 x 7 units, I3 x 2 units & I6 x 4 units
I Anti slam drawers
II Anti slam hinges
III Stainless Steel Dish rack
IV To install cooker & cooker hood
V Internal polyester
C Master Bedroom
1 To design & construct false ceiling w/cover lighting effect
2 To design & construct est L 12 ft full ht wardrobe suing solid-ply laminate c/w internal polyester
3 To design & construct est L 6 ft suspended Tv feature wall using soild-ply laminate (1200m ht)
4 To design & construct est L 2.5ft full ht partition wall using gypsum board
5 To design & construct est L 2ft full ht Tv console using solid-ply laminate
6 To extend clear mirror to 3ft full ht (FOC)
D Bedroom 3
1 To design & construct est L 5.5 ft full ht wardrobe using solid-ply laminate c/w internal polyester
2 To design & construct est L 7 ft suspended study table using solid-ply laminate
3 To design & construct est L 3 ft top hung cabinet using solid-ply laminate
4 To design & construct est L 1 ft full ht partition wall using gypsum board
E Bedroom 2
1 To design & construct est L 6 ft full ht wardrobe using solid-ply laminate c/w internal polyester
2 To design & construct est L 2 ft dresser table using solid-ply laminate c/w internal polyester
3 To design & construct est L 2 ft full ht partition using gypsum board
F Master Bathroom
1 To supply labour to dismantle existing bathroom accessories (FOC)
2 To Supply & install 10mm thick tempered clear glass shower screen (Ht 1900mm +/-)
3 To design & construct est L 5.5 ft suspended vanity cabinet
4 To supply & install est L 5.5 ft kompacplus on top of vanity cabinet
5 To design & construct est L 5.5 ft suspended mirror cabinet using solid-ply laminate c/w mirror (1200mm ht)
6 To supply & install ventilation fan
G Common Bathroom
2 To design & construct shower curb w/ tiles finishing
3 To design & construct est L 2.5 ft suspended vanity cabinet using acrylic
4 To design & construct est L 2.5 ft suspended mirror cabinet using solid-ply laminate w / mirror (1200mm ht)
5 To supply & install shower screen using 10mm thick tempered clear glasss (L-Shape)
6 To supply & install est L 2.5 ft kompacplus on top of vanity cabinet
7 To supply & install ventilation fan
H Miscellaneous works
1 To paint whole unit interior wall using NIPPON / ICI paint (no limit of colour)
2 To lay cardboard protection for working areas
3 To chemical wash the whole unit
4 To clear & discard debris
I Professional Services
1 Design Consolation
2 Space planning
3 3D perspective & detail drawings
4 Material & colour proposal
5 Site Management / Project management
  To provide internal polyester or high rated PVC for all carpentry internal storage
  To provide blum soft closing runner track for all drawers
  To provide soft closing hinges & AA track for all the carpentry
  On 5/26/2016 at 3:48 AM, boon said:
Hi Dunomaxwell, can you kindly PM me your contractor/ID contact  and quotation ? My BTO should be ready by end of the year so doing some research. Love your place! Actually read your blog from start to end, very nicely done up! Thanks for sharing your experiences with the rest of us.
Hi boon,
Thanks for the compliments. PM sent :D
  On 5/25/2016 at 2:43 AM, Raylowwl said:
Hi Dunomaxwell,
Notice your wardrobes are using sliding doors,  could comment how good it is? Comparing with ikea kind?? Am thinking of sliding doors but don't know the reliability if done by contractors? Anything you lookout for? Thanks
Raymond
Hi Raymond,
Because our sliding doors are made of solid-ply wood instead of ikea's chipboard. The sliding doors feels heavier and more sturdy. :P
See whether it is possible to drop by any of your short-listed contractor's customer's house to try out their sliding doors to see their quality.
Due to the size of BTO bedrooms, it was more practical for us to do sliding doors instead of fitted wardrobe doors.
Some things we looked out for when doing our wardrobe
1) is the brand of laminates which they are using. Preferred to be "branded" so the laminates can be more lasting.
2) having "AA" track for our wardrobe shelvings so we can adjust the height of the shelvings to accommodate our possible future needs
3) any limitation to the number of drawers for wardrobe
Two of our bedroom wardrobe has 3 tracks, the 3rd track is for the full height mirror. :)
  On 5/25/2016 at 1:55 AM, melmeow said:
Hi Dunomaxwell, can PM your contractor/ID contact  and quotation ? How much for your reno ? You have some very good and practical ideas in your design.. Thanks
Hi melmeow,
PM sent for ID contact and cost. :)
Thanks. Below is another practical idea by our ID for our living room TV console :D
All TV console "doors" closed
All TV console doors "open" by opening the "doors" and sliding it in
Hi Dunomaxwell,
Raymond
  On 5/24/2016 at 6:03 AM, cinnamoroll said:
Hi Duomaxwell, thanks for your reply. Is it the same laminate for your MBR tv feature wall?
Could you please share the laminate for your living room display cabinet as well?
Thanks!
Hi cinnamoroll,
Yes, our MBR TV feature wall is using the same laminate WY 5217D (Hermes Marcello Walnut).
We are using WY 5214D (CAVALLI VIOLA NOCE) & WY 4232X (PEARL AKEMI ASH) for our living room display cabinet
142225_lhq46WvYtKDruHN%402x_438x620@2x.j
230101_nQ56ZMwP3hl4jKt%402x_438x620@2x.j
Thanks!
