duomaxwell
Llpl's New House @ Punggol Waterway Brooks
  On 1/29/2016 at 4:20 AM, andotang said:
Hi, I am just curious whether you will be removing the red and blue tape in your bathroom as I have seen so many carcass being build over the tape thus making it unremovable. I had mine removed and cleaned the wall before carpentry. I took photos of those tape position before removing. They leave a nasty sticky mess after tearing off, you need strong chemical to remove the residue.
I changed all my switches to Mallia too but I didn't know they have so many colours. After looking at your invoice, I see they are only 20 cents to 40 cents, that give me a choice to change if I want a different colour faceplate. Thanks for the info.
Hi andotang, we plan to leave the red and blue tape for the area which is going to be covered up by carpentry and only remove red and blue tape which is not going to be covered up by carpentry (for easier reference in the future *touch wood if something "bad" happen and water pipe rework is required).
You are most welcome on the info for Mallia switches. You can visit Legrand Mallia website to download their catalogue for their full colour range :lol:
http://www.legrand.com.sg/products/wiring-devices/mallia/?no_cache=1&download=PB014_Mallia_Catalogue_BD__for_Web_.pdf&did=2
Guest Yee Fatt
HI May i know how is the installation of the Kitchen mixer? cause i am planning to get the same thing from insani as well, thanks and appreciated.
Day 32 (28th Jan) - Carpentry Day 3 & Electrical Works (Switches)
Bar Counter & Kitchen top cabinet carcass is up
Electrician is also here to do up the switches (Legrand Mallia)
CCM ran out of stock for 2 gang single pole switches (Pearl Colour). They only left with 7, in total our house need 21, so short of 14. New stock will only arrive after 15 Feb 2016. :(
We made our own purchases of switches from CCM after doing price comparison between different Legrand Mallia reseller in Singapore. CCM was the cheapest. Total cost of switches for the whole house is ~S$371.34 :D
Electrician is helping to change all the switches for the house FOC. :good:
ID recommend us Bronze with Pearl Rocker for the whole house to match our theme and also laminates
Day 31 (27th Jan) - Carpentry Day 2
Toilet cabinet carcass is up
Master Toilet
Common Toilet
Hole for kitchen sink is cut and kitchen sink is mounted
Hole for induction cooker hob is cut
Day 30 (26th Jan) - Carpentry Day 1
Kitchen and Toilet carpentry were delivered around lunch time
Progress by the end of the day
Wet Kitchen Carcass is up
Dry Kitchen Carcass is up
Finally. Tomorrow is the first day of carpentry installation which will start from the kitchen and toilets.
Below are the almost final 2D drawing which is being finalised after 3 long day of discussion with ID and carpenter from 11 Jan to 13 Jan 2016 (everyday from 7pm to 10pm)
Living Room
DB Box
Bar Counter & Dining Area
Kitchen
Toilets
Master Bedroom Wardrobe
Bedroom 2 Wardrobe
Bedroom 3 Wardrobe
Master Bedroom TV Feature Wall & Bedroom 3 Dresser Table
Bedroom 2 Study table
Day 27 (23rd Jan) - Delivery of Kitchen and toilet items
Our ID asked for all the kitchen and toilet items to be delivered today in preparation for the carpentry works in the kitchen and toilet because the last order for kompacplus top before CNY is on the 28th Jan. Which means that the kitchen toilet carpentry need to be up before 28th Jan so that the kompacplus contractor can come down to take measurement.
Since there is a need to cut "holes" by the carpenter for
i) Kitchen sink
ii) Cooker Hob
iii) Common toilet sink
iv) Master Toilet sink
Delivery for the following items were arranged to be delivered today
1) Parisilk - Cooker Hob, Hood, Microwave, Oven
Luckily we were at our new house giving my wife's aunt a tour yesterday (22nd Jan) night because Parisilk called me at 7pm saying that they are nearby, whether they can delivery our items today instead of tomorrow. So all these items arrived at 7.30pm
2) Hoe Kee - Kitchen sink, Common toilet sink & tap, Master toilet sink & tap
3) Harvey Norman - Fridge
4) Courts - Dish Washer
Next up will be carpentry works for kitchen & toilet which will start on the 26th Jan (Tuesday). The rest of the carpentry will only start on the 22nd Feb (Monday) after carpenter is back from 2 weeks CNY break.
Day 26 (22nd Jan) - HERF Flooring Installation by Evorich (Part #2)
Progress after lunch
Door specialist arranged by Evorich to shaved off the bottom of 2 bedroom doors (Master Bedroom & Bedroom #2). Cost for shaving one door is $40. Luckily we only need to shave off 2 instead of 3 doors, but if you look at it from another perspective, it means that the doors supplied by HDB contractor is not of standard. :jawdrop: All are different in height.
Overlay for Bedroom #4
"Humps" installed for the joints
Before
After
Day 26 (22nd Jan) - HERF Flooring Installation by Evorich (Part #1)
The materials are HERF Flooring was being delivered yesterday (21st Jan)
We choose Markham Oak Light hoping it will match the theme of our house
Unboxing of HERF flooring
Progress before lunch
Walkway to the bedrooms
HERF v.s. Parquet
Day 24 (20th Jan) - Chemical Wash
ID initially scheduled the chemical wash contractor to come only come in tomorrow (21h Jan). But the chemical wash contractor came in today (20th Jan) instead.
There is a need clear all the debris, remove all the cardboard protection and chemical wash for areas with cement works (e.g. Wet Kitchen & toilet shower curbs) in preparation for HERF overlay on 22th Jan (Friday).
  On 1/19/2016 at 11:13 PM, duomaxwell said:
ID is charging us $1,200 to supply and install 10mm thick tempered sliding glass door for the kitchen.
Thanks
Day 23 (19th Jan) - 2nd half of partition with wood support using gypsum board for sliding door
False Ceiling contractor came today to close up the other side of the partition after glass contractor came to install the door on the 18h Jan.
Next up will be the chemical wash and area cleaning on the 21th Jan (Thursday) in preparation for flooring HERF overlay on 22h Jan (Friday).
  On 1/19/2016 at 12:30 AM, puteh83 said:
May i know how much is the sliding glass door?
