jibbywong
Balance 4-Rms Flat, 40K Is The Quotation Reasonable?
Hi Everyone,
I have already collected my key since last month but so far still cannot finalize with any id. Seems they are always busy and we needed to keep on calling them to get our quotation. Some got back to us after 3 weeks but some just disappeared.
Here is our first quotation which recommended by our friend. We quite like their design and workmanship but the respond time is pretty slow. Kindly need your help to see..is this too expensive?
Professional Services :
Design Consultation and Space Planning Complimentry
Perspective Drawing and Material / Colour Proposal Complimentry
Project Management and Site Supervision Complimentry
Living / Dining
1. Supply & construct false ceiling c/w L-box or cove light designs (Total 291sqft) 1,450.00$
2. Supply & fabricate L 19ft x D 1.6ft x H 6.5ft wall mounted shoe cabinet, TV console c/w storage & 5,700.00$
display using laminate finish
3. Supply & install L 6ft x H 8.7ft full height tinted mirror at dining area 840.00$
4. Supply & lay 100% waterproof veneer flooring for living room c/w laminated skirting 2,800.00$
(Total 350sqft)
Master Bedroom
1. Supply & construct false ceiling c/w L-box or cove light designs (Total 154sqft) 920.00$
2. Supply & fabricate L 9.6ft x D 6.6ft x H 10" raised platform c/w 100% waterproof veneer flooring 1,800.00$
3. Supply & fabricate L 5ft x W 6.3ft bedframe base for mattress c/w bottom light palmet using 650.00$
laminate finish
4. Supply & fabricate L 6.5ft x D 2ft x H 8.7ft wardrobe c/w dresser & ABS trimming casement doors 1,690.00$
5. Supply & install 2 nos of suspended bedside table c/w storage using laminated finish 840.00$
(Total L 5.6ft x D 1.3ft x H 1ft)
6. Supply & lay 100% waterproof veneer flooring for living room c/w laminated skirting (Total 108sqft) 870.00$
Bedroom 2
1. Supply & lay 100% waterproof veneer flooring for living room c/w laminated skirting (Total 133sqft) 1,060.00$
BEDROOM 3
1. Supply & fabricate L 5ft x D 2ft x H 8.7ft wardrobe c/w ABS trimming casement doors using 1,300.00$
laminate finish
2. Supply & lay 100% waterproof veneer flooring for living room c/w laminated skirting (Total 133sqft) 1,060.00$
Bath 1 (Master toilet)
1 Hack & remove basin & tap 150.00$
2 Supply labour to construct L 5.3ft shower kerb c/w tiles finish 230.00$
3 Supply & install L 5ft x H 6ft 10mm tempered clear glass shower screen c/w 1 nos of fixed panel 650.00$
& 1 nos of sliding door
4 Supply & fabricate L 2.5ft x D 1.5ft suspended vanity cabinet c/w ABS trimming casement doors 380.00$
5 Supply & install L 2.5ft x D 1.5ft soild surface top c/w backsplash 250.00$
6 Supply & fabricate L 4.5ft x D 0.6ft x H 3ft mirror storage cabinet above basin & toilet bowl 810.00$
7 Supply labour to install 1 nos of bi-spray, basin, tap, toilet accessories, 2 nos of inlet piping & 220.00$
1 nos of outlet piping
Bath 2 (Common toilet)
2 Supply labour to construct L 3ft x W 3ft L-shape shower kerb c/w tiles finish 230.00$
3 Supply & install L 6ft x H 6ft 10mm tempered clear glass L-shape shower screen c/w 2 nos of 680.00$
fixed panel & 2 nos of sliding door
4 Supply & fabricate L 3.5ft x D 1.5ft suspended vanity cabinet c/w ABS trimming casement doors 530.00$
5 Supply & fabricate L 3.5ft x D 0.5ft x H 3ft mirror storage cabinet above basin using laminate finish 630.00$
6 Supply labour to install 1 nos of bi-spray, basin, tap, toilet accessories, 2 nos of inlet piping & 220.00$
Kitchen
1 Hack a window opening between living room & kitchen wall (L 3ft x H 4ft) 580.00$
2 Supply labour to change damage wall tiles after hacking of kitchen opening & make good @ $ 30.00 KIV
3 Supply & install 2 panel of alum casement window c/w clear glass at window opening (L 3ft x H 4ft) 580.00$
4 Supply & install L 4ft x H 7ft alum door frame at kitchen entrance 350.00$
5 Supply & install 2 nos of alum swing door c/w clear glass at kitchen entrance (Total 4ft x H 7ft) 980.00$
6 Supply labour to construct L 19.5ft kitchen cabinet kerb c/w tiles finish 480.00$
7 Supply & fabricate L 17.5ft x D 2ft bottom cabinet c/w ABS trimming casement door using laminate 2,100.00$
finish
8 Supply & install L 17.5ft x D 2ft soild surface top c/w backsplash 1,750.00$
9 Supply & fabricate L 20.5ft x H 3ft top cabinet c/w ABS trimming casement door using laminate 2,460.00$
finish (Include above fridge)
10 Supply & install 1 nos of s.steel dish rack c/w frosted glass flip up hydraulic door using laminate FOC
finish
11 Supply labour to install kitchen sink, tap, hob, hood, built-in oven, 1 nos of inlet & 1 nos of outlet 280.00$
piping for kitchen sink (cold water only)
12 Supply & install L 17.5ft x H 2.5ft tempered colour glass backing between top & bottom cabinet 880.00$
13 Supply & fabricate L 2ft x D 2ft x H 8.7ft tall unit for built-in microwave & oven c/w ABS trimming 520.00$
casement doors & drawer using laminate finish
Yard
1 Supply & install L 8ft x H 4ft alum sliding window c/w clear glass panel 580.00$
2 Supply & install L 8ft x H 4ft alum sliding window grills 270.00$
Others
1. Painting for whole house using Nippon or Dulux emulsion paint (No colour limit) 1,580.00$
2. Supply & lay floor protection with corrugated paper/cardboard during reno works 220.00$
3. Haulage of sand, material & debris removal services 250.00$
4. General cleaning & acid wash upon completion for whole house 280.00$
5. Soft closing hinges for all casement doors @ $ 4.50 FOC
Grand Total : S$40,250.00.-
Edited by jibbywong
My ID didn't charge me for soft closing also. As on my research, vinyl/veneer are the same just in different term.
Both are waterproof but no one can 100% guarantee i guess.
All the best!..
Thank you Everyone!
We changed our plan for our master bedroom from platform bed to put a normal bedframe and reduce on carpentry work in the kitchen from both sides top-bottom to one side top-bottom and another side only bottom. The 1st ID (The one I showed you the price) revised his quote to $37,500 but I think it’s still too expensive and his RESPONSIVE is very SLOW…
So my husband & I compared more ID.
First ID – 37,500
2nd ID – 40,000
3rd ID – 32,000 (This ID recommended from our friend (Friend's friend, I think he give us more discount)
4th ID – Still waiting for the price
Actually I’m quite happy with 32k because the meterials are the same but it’s much cheaper. Now we are still consider about it. I think I will finalize soon by end of this month.
i ll update again which ID we have selected and what is final price.
Happy Friday Everyone!
Edited by jibbywong
