diymeister 0 Report post Posted April 11, 2015 hi guys, would any of you have any good suggestions to lower the water pressure into our unit? I live in a condo and I think the water pressure is way too high coming into the unit. The condo water riser only have a flow reducing valve, but that doesn't stop the water pressure from building up when no one is using.it's evident that i keep getting leaking bidets, leaky faucets, and i have some wooden sidings that seem to have water seeping into it.I read that i can use a water pressure reducing valve? is this a common problem that most plumbers know how to address?thanks for the help! Share this post Link to post Share on other sites
GMC 12 Report post Posted April 27, 2015 Pressure does not cause all these leakage.It is the quality of the sanitary ware and the workmanship that causes the leak. Share this post Link to post Share on other sites
