dean 5 Report post Posted April 8, 2015 Can anyone recommend me a reliable plumber, to clear choke sink. How much will it cost? Share this post Link to post Share on other sites
benetay 14 Report post Posted April 8, 2015 Can consider doing it yourself by opening the trap below or use a plunger to clear the airway. What I normally do is simply remove the pipe underneath the sink and let the water flow and remove the dirt. Simple 3-5 mins job unless your piping is different and more complex. Share this post Link to post Share on other sites
w7_lee 11 Report post Posted April 9, 2015 If you do not dispose solid stuff into the sink, then it's probably due to build up of grease (for kitchen sink), then go to normal supermarket to buy drain declogger (drain opener). It's a liquid solution, just pour into the sink, let it sit for a while and then flush with water. Some people recommend DIY declogger using baking soda and vinegar.If you dispose solid stuff down the sink, benetay's recommendation is correct. Share this post Link to post Share on other sites
medr135 0 Report post Posted April 14, 2015 You can always call your Town Council handyman service.These are usually cheaper Share this post Link to post Share on other sites
dean 5 Report post Posted April 22, 2015 On 4/14/2015 at 1:47 AM, medr135 said: You can always call your Town Council handyman service.These are usually cheaperAny contact no. How cheap? Share this post Link to post Share on other sites
