Richard Chia
Advise On My Existing 4Rm Renovation Quote
Hi, Received the below quote..Any advise will be appreciated
No. Description Unit Price All
1 To hack away floor tiles for LH, Kitchen floor tiles, kitchen wall tiles, toilets wall tiles, kitchen cabinets, construct shelves 4,000.00
2 To layover Vinyl Flooring for MBR, BR2, BR3, 447.5sqft 2,950.00
3 To supply and lay 600x600 Homogenous floor tiles for LH, max $3psf 2,850.00
4 To supply and lay 300x600 Homogenous floor tiles for Kitchen, max $3psqft, c/w screeding, 147sqft 1,102.50
5 To supply and lay floor tiles, wall tiles, construct shelf tiles for WC1, WC2, max $3psf 3,500.00
6 To conduct water-proofing for Kitchen, WC1, WC2 700.00
7 To hack away all cornices in LH/Dining 150.00
8 To supply and install false ceiling, L-box, cove lighting according to design mentioned on site 1,680.00
9 To dismantle and install 2 solid veneer doors 600.00
10 To dismantle 3 door, 3 door frame at MBR, BR3, storeroom and make good 360.00
11 To repaint whole unit with ICI/Nippon paint 1,400.00
12 To lay floor with corrugated paper during renovation 250.00
13 Haulage and Disposal of Renovation Debris 1,500.00
14 Acid Wash and General Cleaning upon completion of work 300.00
15 To dismantle all window grilles 350.00
16 To supply and install grey aluminium window grilles to all windows 1,300.00 Subtotal 22,992.50
Masonry Works
1 To hack away wall at MBR facing store, 5.5ft 440.00
2 To hack away wall at BR3, faciing LH, 4ft 320.00
3 To seal up storeroom with Gypsum Board, 3ft x 7ft 150.00
4 To construct 6ft 63mm hollow block wall at Bedroom 3 660.00
5 To frame up side of hobby room entrance with laminate 300.00
6 To construct fridge base 80.00
7 To construct washing machine base 80.00
8 To construct kitchen cabinet base as for item kitchen 1 500.00
9 To seal up MBR, existing entrance to WC1 with Gypsum board, 3ft x 7ft 350.00
Subtotal 2,880.00
Living Hall
1 To fabricate and install 7ft, shoe rack, T.V console, c/w soft closing hinges, laminated ext. 1,200.00
2 To dismantle and reinstall front metal gate 650.00
3 To dismantle and reinstall existing main door 750.00
Subtotal 2,600.00
Kitchen
1 To fabricate and install suspended 40ft kitchen cabinets, c/w soft closing hinges, laminated ext. 4,400.00
2 To supply and install 23ft granite table top 2,990.00
3 To re-run pipe and supply labour to install tap 180.00
4 To construct beam for kitchen facing LH 200.00
5 To supply and install tinted glass panel facing yard, 12sqft 300.00
6 To dismantle and re-install sink 100.00
7 To supply labour to install stove, hood, cooker Complimentary
8 To supply and install frosted glass backsplash 495.00
Subtotal 8,665.00
MBR
1 To fabricate and install 11ft casement wardrobe, c/w soft closing hinges, laminated ext 2,640.00
2 To fabricate and install 9ft shelf at bay window area 990.00
Subtotal 3,630.00
BR1
1 To fabricate and install 5ft casement wardrobe, c/w soft closing hinges, laminated ext. 1,200.00
2 To fabricate and install 7ft shelf at bay window area 770.00
Subtotal 1,970.00
Toilets
1 To build 2 kerbs for tempered glass shower screen 400.00
2 To supply and install fixed panel at kitchen toilet 200.00
3 To dismantle and re-install 2 sitting bowl 200.00
4 To fabricate and install vanity cabinet at MBR toilet, 3ft 900.00
5 To supply and install solid top for vanity cabinet, 3ft 600.00
6 To supply and install fixed tempered glass at MBR toilet 300.00
7 To construct 2 concrete panels 300.00
8 To re-run Stainless Steel piping to both toilets 750.00
9 To supply and install 2 PD door for common toilet, MBR toilet, selected models only 700.00
10 To supply labour to install 2 bidet spray 130.00
11 To dismantle and reinstall 2 washbasin 200.00
12 To install bathroom fittings for 2 toilets 200.00
Subtotal 4,880.00
Electrical Works
1 To install 20 lighting points 640.00
2 To install 2 fan points 76.00
3 To install 1 T.V point 110.00
4 To install 2 telephone point 130.00
5 To install 1 data point 120.00
6 To install 1 heater point, centralized 90.00
7 To install 1 AC point 90.00
8 To install 4 2 X 13AMP D/S 260.00
9 To install 1 1 X 13 AMP S/S 55.00
10 To install 1 hood point, c/w light switch 120.00
11 TO install 8 2 X 13AMP D/S, for rooms 520.00
12 To install and replace 1 D/B box 300.00
Subtotal 2,511.00
Total $ 50,128.50
Edited by Richard Chia
well, this is typical of most quotes. some things cheap, some things expensive.
Example:
shower kerb for $400? wah lau super ex!
but fridge base $80 **** cheap, if it has tiles finishing (cos it never state so)
your house is it 4rm or 4'A'? also got difference.
Lol ya some are cheap some expensive. I rather you look through some of the members reno and see if you want to engage after that. At least there is some proven case for you to sample.
r u serious for this price ?
i hack the entire 4 RM flat floor and wall tiles ( 3 BDR, 1 living rm, 1 dinning hall, kitchen, service balcony, two toilets) plus existing wardrobe in 2 bedroom, plus build in shoe cabinet, also hack two wall, also door removal, cornices..
If you know a cheap price, let me know
