zenstarr 0 Report post Posted March 27, 2015 Good day all,I've just bought aircon for my resale flat.When the aircon guys came to install the aircon, they saw the area where the condenser unit was supposed to be fixed outside the master bedroom window and said the normal brackets cannot be fixed. The reason was that the previous owner had modified the space. Where the wooden panel used to be, was replaced by a window and according to the aircon guys, the metal beam is now missing. Without this metal beam, they cannot install the brackets to support the condenser unit.Is there a metal beam in the first placw for hdb flats? Kindly advise as to what should be done now in order to get the aircon condenser unit fixed. Share this post Link to post Share on other sites
zenstarr 0 Report post Posted March 27, 2015 pictures attached for better explanation of the situation. Share this post Link to post Share on other sites
Tiler Seng 57 Report post Posted March 31, 2015 ask him to bring you to another unit in the same block to explain clearly to you la Share this post Link to post Share on other sites
w7_lee 11 Report post Posted April 7, 2015 Tiler Seng is right, you should check your neighbour's place and bring the SC installer too. My MBR also has such an opening but I had not use it. Still covered with wooden panel (original HDB). There is no metal beam. Share this post Link to post Share on other sites
