derberg 0 Report post Posted December 30, 2014 Hi,Previously I guess reno electrician used a lower grade wire (snap when you pull). During this 3 years, they have to change the wire on those downlights for 4 times and this is frustrating to us. Now I wanted to change all my downlights to LED downlights, how do I ensure my electrician is using better quality wire when rewiring? Or is it better I buy the residential wire (14/2 NM-B recommended by friend in USA) from USA store for the electrician? Does Singapore use the same type of wire as in USA standard? Or anyone knows where can I get a better quality made wire in Singapore?Thanks. Share this post Link to post Share on other sites
benetay 14 Report post Posted December 30, 2014 normal wiring should work, high insulation. Those wire that snap really poor quality, I also think heat could have got the better of it. Share this post Link to post Share on other sites
derberg 0 Report post Posted December 30, 2014 but how do I know they are using good quality high insulation wire? I was told by a friend that the year I do reno, there's few lousy batch of wire in the market and unfortunately this seem to happen to me. Rewiring is expensive and I hope to get it all done nice this time. Share this post Link to post Share on other sites
benetay 14 Report post Posted December 30, 2014 I'm sorry I have limited knowledge on the grades of wire even if I'm an elec engg. I would start with a good and reputable electrician and then ask him questions about it. In the line I work I'm more concerns about connectors then wires so I can't give you a good answer. There are a few threads on electricians you can start from there, I'm sorry I couldn't help you better. Share this post Link to post Share on other sites
wyx03 12 Report post Posted December 31, 2014 I use this type of wire for all downlights and T5 tube.If you want premium grade wires, check out LHS Electronics in Sim Lim Tower. I bought most of my DIY audio grade coax cables, speaker cables and interconnects from there. But, for lighting wires, just buy a normal type like the one shown in the attached photos. 1 Share this post Link to post Share on other sites
tweakmax2 0 Report post Posted February 12, 2015 HiJust to check if this quotation is ok or expensive? Share this post Link to post Share on other sites
myhyip4me 0 Report post Posted February 22, 2015 HiJust to check if this quotation is ok or expensive?Did you do your rewiring with them? Share this post Link to post Share on other sites
ipaq4444 0 Report post Posted March 14, 2015 I use this type of wire for all downlights and T5 tube.If you want premium grade wires, check out LHS Electronics in Sim Lim Tower. I bought most of my DIY audio grade coax cables, speaker cables and interconnects from there. But, for lighting wires, just buy a normal type like the one shown in the attached photos.Hi wyx03, can check with you what brand of wire is that and did you also buy from LSh? Share this post Link to post Share on other sites
