johnnychai 2 Report post Posted December 2, 2014 how do i nail trunking on concrete ?pls helpuse what tool ?or got any powered nail gun Share this post Link to post Share on other sites
johnnychai 2 Report post Posted December 2, 2014 i just wan to learn new thing..may help me in further improvei like diy alot like install LAN point stuff like that..this nail skill may help me alot Share this post Link to post Share on other sites
Freakerz 5 Report post Posted December 18, 2014 (edited) Use a long nose pliers to hold the nails while you use the hammer to knock,save ur thumb and fingers.Another way is the use screws with attached wall plug>Drill your holes together with the plastic trunking and knock the screws with wall plug with a hammer straight.5mm drill bit required for the drilling part.Ask DIY hardware store the kind of screw i mention,buy 1 box is cheaper than buy by loose pieces. Edited December 18, 2014 by Freakerz Share this post Link to post Share on other sites
exxtreme 0 Report post Posted January 6, 2015 Actually there is tool to help you with nailing with a regular hammer. The link is a post for nailing a picture but the tool is the key =) it makes you nail like a pro.http://www.home-dzine.co.za/diy/diy-picture-hang.htm Share this post Link to post Share on other sites
pentiumpc 0 Report post Posted January 14, 2015 diaso sell a slightly bent long nose plier. Share this post Link to post Share on other sites
bepgof 20 Report post Posted January 24, 2015 With OMO, not easy to hold trunking, nail, hammer.....at one time.What i did, put thin double side tape on trunking......one hand hold nail, another with hammer.Make sure steel nail, not iron nail. Application on concrete wall, i meant Share this post Link to post Share on other sites
Buzzy 0 Report post Posted July 19, 2015 Are there sizes (thickness) for the nails ? Share this post Link to post Share on other sites
WordSmith 45 Report post Posted November 6, 2015 Are there sizes (thickness) for the nails ? usually those 1 cm short ones, tell the hardware shop is for wall trunking, they will know it Share this post Link to post Share on other sites
