Syahrudin Wacko
Is My Quote Reasonable For Premium Bto 4 Room?
received a quote from an ID.
was wondering if its reasonable.
Living Room Works
- Fabricate & install 6 Ft. full height TV Feature wall using solid plywood with laminate finish. 1180
- Fabricate & install 6 Ft. suspended TV console c/w drawer using solid plywood with laminate finish. 950
- Install L-box & false ceiling with pulmet to living hall 680
Master Bedroom Works
- Fabricate & install 6 Ft. full height sliding wardrobe using solid plywood with laminate finish. 1380
- Fabricate & install 5ft half height TV feature wall in laminate finish to master bedroom 480
- Install L-box & false ceiling with pulmet to master bedroom 480
Bedroom 2 Works
- Fabricate & install 5 Ft. Full height sliding wardrobe using solid plywood with laminate finish. 1150
Bedroom 3 Works
- Fabricate & install 5 Ft. full height sliding wardrobe using solid plywood with laminate finish 1150
Kitchen Works
- Fabricate & install 10 Ft. bottom cabinets with drawers using solid plywood with laminate finish c/w anti slam hinges. 1450
- Fabricate & install 10 Ft. bottom cabinet using solid plywood with laminate finish c/w anti slam hinges. 1450
- Supply & install 20 Ft. solid surface kitchen worktops based on abovementioned cabinets. 1360
- Supply & construct 50 mm thick cabinet base, fridge base & Washing machine base. 450
- Supply Labor and material to install anodized B/S color sliding aluminum window for service balcony 580
- Upgrade to i-Quartz additional top up: 1040
Painting Works
- Provide material & labor to paint whole house using Nippon Premium paint ( up to 5 color's ) 1250
Bathroom and Plumber Works
- Supply labor to install kitchen accessories, kitchen sink. 80
- Supply labor to install bathrooms accessories, mini spray and water heater x 2 bathroom. 100
- Supply Labor and material to install 10mm clear tempered fix panel shower screen with swing door c/w towel holder at master bathroom 600
- Supply Labor and material to install 10mm clear tempered fix panel shower screen with swing door c/w towel holder at common bathroom 600
- Supply Labor to install 2 x vanity cabinets and 2 x mirror cabinets (provided by client) 200
Electrical Works
- Connect cooker hob and hood 1 no's at kitchen. 120
- Connect doorbell existing point. FOC
- Install whole house light at existing points. 10 pts 100
- Install 2 no of ceiling fans **** room and Master bedroom 200
Miscellaneous Work
- Provide labor for chemical washing for whole house twice. 220
- Provide necessary protection layer sheet at affected area during renovation. 200
Provide 3D perspective drawing
- Design and consultation FOC
Total: $17,450 nett
for my kitchen, i will doing 2 bottom cabinets instead of top and bottom being vertically challenge. :P
is the price alright?
still looking around.
most ID requires me to come down their showroom for discussion which i currently dun have time for..
only this id gave me through email and also thru whatsapp..
he told me, this is just the rough price.
could be cheaper when he come down and take the actual measurements.
still very busy to meet up with him..
you can try my ID from Spazio Interior Elements.
Designer's ideas and works at contractor's price. ( always heard from him say this many times )..
PM me for his details... ( I promised him i will definitely recommend clients for him ).
My Condo was done up by him efficiently at a reasonable price..
