AirconBestValue
Hi Michelle,
Please quote the following for 5 rm BTO which I like to air con 3 bed rooms, 1 study room, 1 living room.
MITSUBISHI SYS 3 - INVERTER (2 ticks)
MXY3A28VA
MSYGE10VA x 02
MSYGE24VA  x 01
MITSUBISHI SYS 2 - INVERTER (2 ticks)
MXY2E20VA
MSYGE10VA x 02
- installation
- 1/2" Armaflex class "0" insulation
- G22 copper pipe with PSB Tested
- 16mm diameter with ¼’ thinness insulation
- Cables – 4C40,4C70 with PSB Tested
- PVC Trunking – minimum 2mm thick
- additional cost for length of pipe used ?
- warranty (parts and installation)
Hi Michelle,
Would appreciate if you can quote me the following. My place is a 5rm HDB with a built study. Therefor, need to cool 3 x Bedroom, 1 X Living Room + Dining Room, and 1 Small Study.
Daikin. System 3. (Two Sets)
FTKS20KVMA X 2
FTKS25 KVMA X 1
Also, as per above, please provide broken down cost for:
- installation
Thank you.
Hi Michelle,
Would appreciate if you can quote me the following. My place is a 4rm HDB resale. Looking at either this 2 specs.
Daikin. System 3 Spec 1
3MKS71FSG / FTKJ25NVMS x 2 + FTKS60FVM
Config 2
3MKS71FSG / FTSK25DVM x 2 + FTKS60FVM
- installation
Thank you
  On 5/30/2016 at 3:14 PM, ChasingStars said:
Hi Michelle
I'm looking at 2 quotations - Type: Landed
Kindly quote me on Mitsubishi Starmex (2 ticks), including installation and GST, for the following;
1) System 1 x4
- 12k BTU x2 (bedroom)
- 18k BTU x 1(bedroom)
- 24k BTU x 1(bedroom)
2) System 1 x2 & System 2 x1
System1 x2:
- 12k BTU x1 (bedroom)
System 2 x1:
12k BTU & 18k BTU(bedroom)
Please include the following;
-installation (1 time installation)
- G22 copper pipe
-16mm drainage
-additional cost for any length of pipe used for installation?
-warranty (parts and installation), etc....
Please break down the cost.
Regards,
Michelle
  On 5/31/2016 at 10:22 AM, KeVnAsH said:
Hi Michelle,
I am considering 2 replacement options for my current 7-8 years old condo aircon system.
Option 1: Mitsubishi Electric System-2 ×2
MXY3G20VA
MSXY-FJ10VE x 02
MXY3G20VA
MSXY-FJ18VE x 01
Option 2: Mitsubishi Electric System-3 x1
MXY3G28VA
MSXY-FJ10VE x 02
MSXY-FJ18VE x 01
Hope to receive a quote from you soon for my consideration.
Regards.
Kevin
Regards,
Michelle
  On 6/1/2016 at 9:14 AM, pandaboxer said:
Hi Michelle,
MXY3A28VA
MSYGE10VA x 02
MSYGE24VA  x 01
MXY2E20VA
MSYGE10VA x 02
- installation
Regards,
Michelle
  On 6/2/2016 at 9:15 AM, peabrainpun said:
Hi Michelle,
FTKS20KVMA X 2
FTKS25 KVMA X 1
- installation
Thank you.
Regards,
Michelle
Hi Michelle,
I will like to get quotation for myself and my friend's house below:
Quote 1 - Landed Property
Panasonic single split - CU-XS9RKZ (new model, 9000 BTU)
Quote 2 - HDB
Panasonic system 2 - CU-2XS18RKZ (new model, 2 x 9000 BTU)
For survey, is it available on weekend or after 6PM?
I have a resale (with 4 bedrooms) condom which is about 16 years old.
Can you quote  system 2  12K BTU x 2 cooling units
and another system 2 with 18K BTU x 2 cooling units? Mitsubishi preferred
Can u advise whether the existing piping can be retained especially for the 18 BTU?
  On 6/12/2016 at 3:14 PM, lipton said:
Hi Michelle,
Quote 2 - HDB
Regards,
Michelle
Please quote for System 4 Mhi (3ticks). 5 room BTO, Bedrooms 13k BTU, Living 38k BTU.
Kindly include GST
 -installation
 - G22 copper pipe
 -16mm drainage
 - additional cost if any
 - warranty
thanks
  On 6/13/2016 at 12:58 AM, mayotedy said:
Regards,
Michelle
  On 6/15/2016 at 9:53 AM, moomoosg said:
hi,
I have a 4 rm
Can you quote  system 3  9k BTU x 3 cooling units. looking for a budget brand as it for rental flat
Regards,
Michelle
Hi, I'd like a quote for the Daikin System 3. I'd like to see the price for [3mks71fsg, 3 x FTKS25DVM]. Please include the exact specifications and brand of the materials to used (such as SWG22/23, 3/8 or 1/2 inch insulation). Bracket and powerpoint charges as well. Thanks.
