AirconBestValue
Hi you might have missed my request :)
I am looking for a System 4 for my new BTO. Looking at 3X 9K + 1x 18K BTU.
Prefer Panasonic/LG/Samsung
1/2" Thick Armaflex Insulation
G22/G23 Copper Piping
16mm Drainage
Inclusive of Installation.
please give me a quote, thanks!
Regards,
Chris
Hi, please give me a quote for the following:
- System 2: 9k X 2
- System 3: 18k X 1 + 9k X 2
- is there system5 with all above?
Prefered brand of the spec above:
1. Mitsubishi Electric
2. Panasonic
3. Daikin
Quote shall include installation with:
- Armaflex insulation “O” 1/2inch
- G23 copper pipe
- keystone wire
- 16mm drainage pipe
- System 2: 9k X 2
2. Panasonic
3. Daikin
- G23 copper pipe
- keystone wire
Regards,
Chris
Guest Shan Chua
Hi pls quote for ME or daikin sys 4 (24k btu x 1 and 9k btu x3). its a bto
I am thinking of replacing my current System 3 (10 year old) with a StarMex/Daikin System 3/4.
I wish to have an outlet with higher output for my master bedroom if feasible.
I am unsure if I can reused my exisiting pipes which run behind a custom wardroom. If I have to change the pipes, how much will it cost to dismantle and reassemble the wardrobe?
Please quote the price for Mitsubishi Starmex MSY Series System 3(18k BTU X 1 + 9k X 2) for HDB 4 room. Currently my unit is not install with 15AMP power point, do I need to change to a 15amp point.
Thanks,
Jas
Hi Chris, can you please quote me for a system 4 unit. My current system is 10 Yr old Daikin and I just bought a brand new compressor unit.
Main issue is the re-piping as its external but runs through a build in wardrobe and I prefer not to remove the wardrobe.
Drop me a note and thanks
Dear Renotalk sis/bro, We are doing promotion for brand such as Daikin, Panasonic, Mitsubishi etc. What are you waiting now?...... Ask a quote from us at once.Remember tell us what brand are you prefer ? How many system 1/2/3/4 ? Cooling capacity 9K BTU/ 12K BTU/ 18K BTU / 24K BTU ? property type HDB/BTO/Condo/landed ? We will reply you as soon as possible with promotion :good: Warmest Regards,Chris
Hi Chris ,
Hi Chris , can quote me the cost for Starmex sys4 ,
MXY - 4A28VA
MSY - GE18VA -01 unit
MSY - GE10VA -03 unit
Upgrade:
1/2 thick insulation
22 copper pipe
16mm Dorian pipe
Use 3C x 40 wire
Please pm me your number also. Thanks
Regards,
Chris
Thanks,
Jas
Regards,
Chris
Regards,
Chris
Hi Chris ,
MXY - 4A28VA
Upgrade:
22 copper pipe
16mm Dorian pipe
Use 3C x 40 wire
Regards,
Chris
Warmest Regards,
Chris
I would like to install new 2 units of aircon, tear down existing and redo the aircon piping. Can quote me? would prefer mistsubishi aircon.
