AirconBestValue
Hi Chris,
Please quote me ME System4
3 X 9000 BTU
1 X 1800 BTU
To replace my existing LG System 4. HDB 5RM
Can the old pipe be re-use?
Thank you.
Regards,
Desmond
Regards,
Chris
I am looking for a System 4 for my new BTO. Looking at 3X 9K + 1x 18K BTU.
Prefers Panasonic/LG/Samsung
please give me a quote, thanks!
Edited by grhu8175
Hi, please give me a quote for the following:
- System 3: 9k X 3
- System 2: 18k X 1 + 9k X 1
Prefered brand of the spec above:
1. Mitsubishi Electric
2. Fujitsu
3. Daikin
Quote shall include installation with:
- Armaflex insulation
- G23 copper pipe
- keystone wire
- 16mm drainage pipe
- System 4: 9k X 3 + 18K X 1
- System 4: 9k X 3 + 22K X 1
2. Carrier
3. Daikin
- Armaflex 1/2 inch insulation
- G22 copper pipe
- keystone wire
- stainless steel bracket
- System 3: 9k X 3
2. Fujitsu
3. Daikin
- G23 copper pipe
- keystone wire
Regards,
Chris
- System 3: 9k X 3
1. LG
2. Mitsubishi Electric
3. Daikin
Thanks in advance
Regards,
Chris
2. Carrier
3. Daikin
- G22 copper pipe
- keystone wire
Regards,
Chris
Hi Chris,
Please provide quite for Fujitsu sys 3 aircon + install (AOAG24LAT3/ASAG12LJ + O9LJ x 2).
To remove existing sys 2 aircon/compressor and replace/extend ducting as required
Pls advise the warranty (piping, fancoil,compressor) provided with the aircon purchase and period of coverage for workmanship too.
Hi Chris,
Regards,
Chris
Please kindly quote for a system 4 system with 3 fan coil for my resale unit. Will install the 3 bedroom first and living room will install later. Do note my resale unit loading is only 8.5amp.
- Compresser: 4C100VA
- fancoil: 03 x 9,000 btu
- Stainless Steel Bracket
- removal of old window type aircon
- 20A isolator
- 1 trip installation
Material:
1/2″ Inch Thick Armaflex Insulation Class 1
G23 (0.61mm Thickness) Copper Piping
3 Core 40(fancoil) & 70(compressed} Wire Cable
16mm Diameter Drainage Pipe, 3/8" insulation for horizontal pipes.
Would like a quote for:
System 4 (Mitsubishi Starmex)
27k btu x 1
12k btu x 1
9k btu x 2
3/8" Thick Armaflex Insulation
G22 Copper Piping
16mm Drainage
Inclusive of Installation.
Thank you.
- 20A isolator
Material:
Regards,
Chris
27k btu x 1
12k btu x 1
9k btu x 2
G22 Copper Piping
16mm Drainage
Thank you.
Regards,
Chris
Hi you might have missed my request :)
Prefer Panasonic/LG/Samsung
1/2" Thick Armaflex Insulation
G22/G23 Copper Piping
16mm Drainage
