skoh
'moh Bing' Walls And Ceiling
Hi all
Is there anyone who is able to advise how to smoothen the uneven wall texture? I was told the 'moh bing' effect was sprayed on. Should the wall and ceiling b smoothened out by first evening the surface before plastering or should straight away plaster the walls and ceiling. By adopting the latter, the thickness of walls and ceiling will increase slightly. Of coz this will b a cost effective method. Any other negative implications?
Those are called rockstone was popular in the 80s. Plastering is prefer, thickness increase likely about 2 to 3 mm. I hope yours is flatten and not those super rough effect which is mainly for outdoors..
Thanks Blackie! Now I know this is the name for 'moh bing' walls... kaka =D
Mine are not super rough but small and many...
Hope the plastering works well...
yup..cost about $2k++.
hope the result will be good! Just started my reno...nx will be plastering...
I read that plastering is to b done after rewiring. is this true?
