Homesweethome
How To Take Out Mirror Attached To Walls Before Hacking Off The Wall?
May I know is it ok to ask contractor to take out the big mirror before do the wall hacking so that I can keep that big mirror and use it at another place?
I just feel wasted if just hack everything off..
Of course you can. Just unmount it. Or if use silicon, just cut with a box cutter think here in Sg you call it penknife) :)
If glue though..I suppose u can ask them to hack around it with a tile chisel then later on when it's off the wall you can try to slowly hack off those tiles bit by bit? Use steam (from a large pot of boiling water or those clothes steamer) to try n loosen the glue behind. Depends on the glue used I guess..
