fengshui21
Effective Fengshui
4 ways how to improve the energy of your home/office
Feng shui is very old system of harmonizing the environment and any expert in this area will tell you how best to arrange the furniture, what subjects to furnish the room to create a favorable background. But there are additional factors that have a strong impact on our health and well-being and if we are often in contact with them, we can lose up to 40-50% of our vital energy, labor activity and health. Here are some of them:
1. Geopathic zones. For example, if under the place where you live or work are underground rivers, which form strong eddies. Or it could be a stone slab with a large number of faults, and energy vibrations of these places will strongly influence your mood and create a sense of anxiety, poor sleep, reduce performance and even cause some diseases.
2. Certain forms of geometry also affects the way we feel. There are always a lot of things that have an angular shape. Such objects are strong emitters of energy and can break energy structure, which also entail leak forces.
Therefore it is very important to pay attention to how objects are located in areas of your permanent residence, especially if it's sleeping area. It is not a good idea to put a massive pedestal beside the bed, if one of its angles is constantly directed at your sleeping body. Or hang a chandelier over the bed with sharp elements. You will sleep poorly, feel overwhelmed.
3. Another important point - it is the place of production of the interior items and their composition. If a factory located at some unfavorable position, the products produced by it will detect this condition and subsequently affect on the energy of the houses. Such items are usually not a lot of danger and are only a few categories:
- Subject is created in a place where a very low energy density, the so-called yin place, then it will make up for this deficiency, draining energy from the surrounding space. Here it is necessary to look at the degree of manifestation of such a property, because there are things slightly suck energy. It's not critical for your health. But there are some things "vacuum energy", which will eat away your energy and in this case it is better or get rid of it, if it does not carry much value, or clean from the Yin energies. In identifying and cleaning of such items you can contact us.
- Rare, but quite dangerous objects formed as a result of very strong energy processes - a volcanic eruption, meteorites. It is rather rigid vortex, which is in contact with the subtle bodies of their human tears. Some kind of energetic grinder. These items can also be cleaned, destroying the thin margins that create such a strong vibration.
- Objects produced of toxic substances (usually a synthetic material). If it's just a table cover, it will not greatly affect the well-being, but if a mattress for a bed, a blanket or pillow is energetically aggressive synthetic material, then it is really significantly for our relax and good energy flows. You will have a bad sleep, it can decrease the activity and the state of health can be damaged.
- And one more category of items that have a very complex energy configuration. Standard stone typically has two to four energy bodies. But there are natural anomalies, when the stone has 7 or 12 energy bodies. Every time the man passed such stone, he will face their slender bodies and tear his energy structure. It also can harm the health and life activities.
4. And another rare phenomenon - the so-called poltergeists, or restless soul. To determine the statistics, how often they occur, we investigated the 400-apartment building, which is 50 years. In 8 apartments we found active undead souls - "Poltergeist". And only one of these souls was aggressively tuned to tenants and wanted to harm people. With these problems we may encounter in older homes, and our experts can solve the problem appease these souls.
Sure, there are not all apartments with all of these components. According to statistics, about one in two will be in a pretty good condition for being, the other half will contain a few of these factors moderate and negative impact on the emotional and physical condition of the residents. But somewhere in the 12th-15th of each apartment there are already quite dangerous objects which have a serious impact to health.
If you feel at a constant lack of strength, weakness, bad enough sleep, if you are uncomfortable to be in any place, you cannot find a place, you always want to get away from there, it's hard to concentrate at work, we recommend that you make the diagnosis of your apartment or office. Our experts will help you to identify these problem areas and if you wish to remove them.
The whole procedure is done remotely! For the audit, we need some photos of the test room or office. We will prepare a detailed description of the energy state at your place. The next step will be the correction, it can take 2-3 days. In our experience, you will feel an improvement in your mood and well-being immediately after the procedure.
In addition, it is desirable to make the preliminary audit of property before buying it. Including some standard factors like prices, sizes, etc., people are always focused on their feelings, and if you plan to spend a few years, it's worthy to get an energy audit of this place. If you can not sell your property, you can also contact us, and if we will identify some of the above points, we can help you to eliminate them.
The whole procedure of cleaning the room - a one-time event. Cleaning the place or objects from negative vibrations, you can be sure that they will not recover.
If you have any more questions or want to get a preliminary audit of your home/office, feel free to contact us: enfengshui@yahoo.com.sg
We give you 1 room fengshui audit for FREE! Just send the photo of the whole room. You'll get a detail description within 24 hours.
