HSHome 3 Report post Posted July 20, 2014 Hi, intend to engage contractors directly instead of going thru ID company for carrying out the following works to my parents' flat:a) Replace gate to stainless steelb) Replace sliding windows & grilles to natural anodizedc) Tidy cable trunking, & replace ceiling/ wall lights to LEDd) PaintingThe flat is occupied while conducting the above works.Would appreciate advice as to the sequence of works & responsible contractors for each trade.Many thanks. Share this post Link to post Share on other sites
HSHome 3 Report post Posted October 23, 2014 Finally found contractor for the metal works and painter. Will provide a review after works done.Now left the electrician... Appreciate recommendations of reliable & qualified ones. Need to engage the service urgently.Thanks. Share this post Link to post Share on other sites
Humphrey 0 Report post Posted October 23, 2014 Bro, You can do the metal works and electrical works concurrently and painting works to be done after.This should shorten the time frame which your parents might be inconvenienced.For electrician, you may want to try JGEC - 81577555. Used them for my EM, so far no issues yet.Hope this helps,Humphrey92999451 Share this post Link to post Share on other sites
kaisharon 1 Report post Posted October 29, 2014 Hi humphrey, How does JGEC charge? Thanks Share this post Link to post Share on other sites
nerrad 7 Report post Posted October 30, 2014 What's the current material of your window and grille? Share this post Link to post Share on other sites
HSHome 3 Report post Posted November 8, 2014 Aluminum to aluminum. Couple of the sliding windows jammed up, the ironmongeries also starting to drop off. The last straw - window films scaling & oxidising which gave the windows an unkempt look.. No choice, got to replace the windows & grilles then.What's the current material of your window and grille? Share this post Link to post Share on other sites
