HSHome
Sequence Of Works (Advice Needed)
Hi, intend to engage contractors directly instead of going thru ID company for carrying out the following works to my parents' flat:
a) Replace gate to stainless steel
b) Replace sliding windows & grilles to natural anodized
c) Tidy cable trunking, & replace ceiling/ wall lights to LED
d) Painting
The flat is occupied while conducting the above works.
Would appreciate advice as to the sequence of works & responsible contractors for each trade.
Many thanks.
Finally found contractor for the metal works and painter. Will provide a review after works done.
Now left the electrician... Appreciate recommendations of reliable & qualified ones. Need to engage the service urgently.
Thanks.
Bro,
You can do the metal works and electrical works concurrently and painting works to be done after.
This should shorten the time frame which your parents might be inconvenienced.
For electrician, you may want to try JGEC - 81577555. Used them for my EM, so far no issues yet.
Hope this helps,
Humphrey
92999451
Aluminum to aluminum. Couple of the sliding windows jammed up, the ironmongeries also starting to drop off. The last straw - window films scaling & oxidising which gave the windows an unkempt look.. No choice, got to replace the windows & grilles then.
What's the current material of your window and grille?
