bianzi 52 Report post Posted August 5, 2014 Ya law. At least tell us in advance ma... If I know I go question u for wat? Seriously law .. Those experienced uncle super take pride in their work.. Of course I felt cheated cos I paid extra for the 1/2 inch lei. System 4 Mitsubishi electric for $4380 is not the super cheaper type I also got similar problem and similar answer as you. Except that in my case, the contractor was not angry but also explained no space, if use thicker will damage etc, if I really want, they will rip out the old trunking, put in the new trunking, but if damage cannot blame them etc etc. Alamak, basically put me in a spot, so much so that I decided to just leave it. I think it is not that we really want the thicker ones, but we feel kind of "cheated". If contractor wants to use some other size, should at least tell us before doing so. Share this post Link to post Share on other sites
koori 45 Report post Posted August 5, 2014 LocksMiss Gadget is thinking if she wants to change the locks for her house to electronic ones... Need to find one with the handle (as i can't stand the currently brass looking handle on the door) and the YALE series look quite nice... (another expense...) decisions...Do you guys think there is a need to have the thumb print recognition function? ... My sis's place main door has electronic with fingerprint function....If you usually have problems with fingerprints recognition devices then you will have problems with this fingerprint technology. Niece's hands not sure is too wet or too dry or too whatever....her fingerprints can never clear the Singapore custom's biometric gates coz her thumbprint cannot be matched.And her fingerprints can't clear her home's electronic door lock as well. Always gets an error message. She's using password to unlock the door. It doesn't have to be the thumb by the way. I see my sis registered her forefinger print. 1 Share this post Link to post Share on other sites
Dwinsplace 48 Report post Posted August 6, 2014 I agree with kstoh. At the end of the day, we just want to get what we paid for and know whats going on. It's difficult cos we have limited knowledge of what needs to be done but we're investing a lot of money.Anyway, I did some scouting of my new aircon pipes. The copper was insulated with H class all the way. However the drainage pipe was insulate with a thin D class only. I questioned and got a rather patient and detailed reply which I shall cut and paste here for everyone's learning. "Good evening!Armaflex H-010 grade half inch insulation only use on all copper refrigeration pipe, no aircon man will use on drainage pipe, drainage pipe will use lower spec insulation.Its because1. No required as drainage pipe is use for drain out cool water which is not as cool as refrigeration pipe2. If use the same spec for both drainage and copper refrigeration pipe the minimum trucking size will be at least five by five inches3. Industries practice for thinner spec for drainage pipe, Mitsubishi professor also meant it before when I taking good installation practice class at Mitsubishi building in last year July.4. No issue happened before as we find it also no any needs to use a different spec as normal practice to make piping in longer term usage" My other interior design sources seem to be happy with this explanation. so i'll let it go. 1 Share this post Link to post Share on other sites
bianzi 52 Report post Posted August 6, 2014 Sigh as u can see for mine? It was used on the copper pipes... So I am not sure how they connect the h class to this F classI agree with kstoh. At the end of the day, we just want to get what we paid for and know whats going on. It's difficult cos we have limited knowledge of what needs to be done but we're investing a lot of money.Anyway, I did some scouting of my new aircon pipes. The copper was insulated with H class all the way. However the drainage pipe was insulate with a thin D class only. I questioned and got a rather patient and detailed reply which I shall cut and paste here for everyone's learning. "Good evening!Armaflex H-010 grade half inch insulation only use on all copper refrigeration pipe, no aircon man will use on drainage pipe, drainage pipe will use lower spec insulation.Its because1. No required as drainage pipe is use for drain out cool water which is not as cool as refrigeration pipe2. If use the same spec for both drainage and copper refrigeration pipe the minimum trucking size will be at least five by five inches3. Industries practice for thinner spec for drainage pipe, Mitsubishi professor also meant it before when I taking good installation practice class at Mitsubishi building in last year July.4. No issue happened before as we find it also no any needs to use a different spec as normal practice to make piping in longer term usage" My other interior design sources seem to be happy with this explanation. so i'll let it go. Share this post Link to post Share on other sites
bianzi 52 Report post Posted August 7, 2014 Updates updates... finally some traction (4th week!)Let the pics do the talking My beloved kitchen tiles I know it is not as nice to put on the skirting.. but for practical reasons.. i decided to go aheadMy contractor is very proud of this.. I think my switches are a little too low... i asked for 11 inch but i think the electrician went lower than that.. this means that my tv console ... i can't get one with high legs... Share this post Link to post Share on other sites
bianzi 52 Report post Posted August 7, 2014 (edited) C used cement and tiles to make this ledge... quite nice and neat Edited August 7, 2014 by bianzi 1 Share this post Link to post Share on other sites
bianzi 52 Report post Posted August 7, 2014 (edited) Lights update...All delivered...AZ elite recommended by this phylux lighting...looks pretty small..my doubled priced toshiba spot lightsugly kitchen philip lights (made in india) which is not flat....toilet and service yard lightsPhilip bedroom lights.. the 75w led master bedroom dimmable light Edited August 7, 2014 by bianzi Share this post Link to post Share on other sites
Dwinsplace 48 Report post Posted August 8, 2014 Sigh as u can see for mine? It was used on the copper pipes... So I am not sure how they connect the h class to this F classSorry to hear it. But to answer your question: they use duct tape to connect the insulations mostly. Industry practice. 1 Share this post Link to post Share on other sites
bianzi 52 Report post Posted August 8, 2014 This is the 污点 in my house !Sorry to hear it. But to answer your question: they use duct tape to connect the insulations mostly. Industry practice. Share this post Link to post Share on other sites
lovescandi 42 Report post Posted August 8, 2014 Arrivals from wasser bath Love your sink! Share this post Link to post Share on other sites
Troublemaker 31 Report post Posted August 9, 2014 I also got similar problem and similar answer as you. Except that in my case, the contractor was not angry but also explained no space, if use thicker will damage etc, if I really want, they will rip out the old trunking, put in the new trunking, but if damage cannot blame them etc etc. Alamak, basically put me in a spot, so much so that I decided to just leave it. I think it is not that we really want the thicker ones, but we feel kind of "cheated". If contractor wants to use some other size, should at least tell us before doing so.I guess i am luckier in this sense. My aircon guy told me that they will use the thick insulation and hence, the trunking will be huge. The previous owner used a smaller insulation and thus, a smaller trunking. Share this post Link to post Share on other sites
bianzi 52 Report post Posted August 9, 2014 I dunno why they did not suse the huge insulation for me? I will be boxing up anyway.! **** sian .. Now all boxed up. Cannot ask him to change I guess i am luckier in this sense. My aircon guy told me that they will use the thick insulation and hence, the trunking will be huge. The previous owner used a smaller insulation and thus, a smaller trunking. Share this post Link to post Share on other sites
bianzi 52 Report post Posted August 9, 2014 (edited) Last update before I go overseas for the next 3 weeks! Finalized the laminate colours for kitchen, wardrobe and shoe cabinet today with ID... yes I engaged an id for my carpentry.. Haha very different from the others...Bricks wall is done! Although over used by many homes,, it is still nice to look at ..Kitchen subway grouting done Edited August 9, 2014 by bianzi 1 Share this post Link to post Share on other sites
StevenNg 6 Report post Posted August 9, 2014 very nice bricks... how much approximate for this kinda area w installation? thanks 1 Share this post Link to post Share on other sites
bianzi 52 Report post Posted August 9, 2014 I think it is about $1.8-1.9k to do a wall. But then again depends of the size of the wall... very nice bricks... how much approximate for this kinda area w installation? thanks Share this post Link to post Share on other sites
