Ken82
Please Advise Me If My Renovation Quote For Tampines Greenleaf (4 Room Bto) Is Reasonable?
Dear Housing Gurus,
I have begun to look for my ID to do my house and got this quote from a very attentive ID.
I really need inputs from you guys, thank you and I have learn a lot of knowledge from this great forum.
Will you guys kindly advise me if the following quote is cheap, reasonable or expensive?
Interior Designing & Services Includes:
* Design Concept & Budget Consultation * Soft-Furnishing Consultation
* Space Planning & Layout Plan Proposal * Computer Design Drawings Proposal
*5 Years Workmanship Warranty With After-Sales Services * Materials & Colour Scheme Proposal
Haulage Works
1 Uploading of building materials and sand to site
2 Removing of debris from site
Masonry Works
3 Construct 50mm ht. kitchen cabinets base
4 Construct 50mm ht. fridge base
5 Construct 50mm ht/ washing machine base
Plumbing Works
6 Extension of stainless steel pipes to new kitchen sink position
7 Extension of stainless steel pipes to new washer position
8 Supply labour for kitchen sink and mixer installation
9 Supply labour for bathrooms instant heater installation
10 Supply labour for bathrooms accessories installation
Plaster Works
11 Construct false ceiling at foyer area
12 Construct false ceiling / light holder **** hall
13 Construct false ceiling / light holder at dining hall
14 Connstruct false ceiling at bedroom passage
Carpentry Works
[all carpentry will be using solid plywood with standard laminate selections up to $60 and
white internal pvc]
15 Design and fabricate 20ft L top and bottom kitchen cabinets
16 Supply and install 10ft L polyester base solid surface worktop
17 Supply labour for hob/hood installation
18 Design and fabricate 6ft L x 6ft H TV feature wall panel **** area
19 Design and fabricate 6ft L suspended TV console **** area
20 Design and fabricate 6ft L x 6ft H mirror feature at dining area
21 Design and fabricate 6ft L full height casement doors wardrobe
General Works
22 Supply Labour & DULUX emulsion paint for whole house walls and ceilings
23 Laying of flooring protection before start work
24 General washing for the whole apartment before handing over of project
HDB 4-Room Premium Flat Package $ 10,688.00 (As Above)
Additional Works
A. Masonry Works
1.1 Construct 50mm ht. shower kerb at master bathroom $ 100.00
1.2 Hack existing ramp and main door entrance and lay matching living area tiles $ 80.00
B. Carpentry Works
[all carpentry will be using solid plywood with standard laminate selections and
white internal pvc]
Living Area
2.1 Design and fabricate 5ft L full height shoes and display cabinet 1 set $ 1,500.00
2.2 Design and fabricate 6ft L suspended TV console with glass doors 1 set $ 240.00
(top up to package item 19, suspended laminated TV console)
Bedroom 3
2.3 Design and fabricate 6ft L full height laminated sliding wardrobe 1 set $ 1,560.00
(c/w sliding mirror at side of wardrobe)
Bedroom 2
2.4 Design and fabricate 5ft L full height laminated sliding wardrobe 1 set $ 1,300.00
Master Bedroom
2.5 Design and fabricate 6ft L full height laminated sliding wardrobe 1 set $ 120.00
(top up to package item 21, 6ft L full height casement wardrobe)
2.6 Design and fabricate additional 1 L full height laminated sliding wardrobe 1 set $ 260.00
2.7 Design and fabricate 4ft L x 6ft H TV feature wall panel 1 set $ 600.00
2.8 Design and fabricate 4ft L suspended TV console with glass doors 1 set $ 640.00
Kitchen
2.9 Design and fabricate 1ft L 8.5ft H laminated plank to cover fridge backing 1 set $ 280.00
2.10 Design and fabricate additional 9ft L kitchen cabinets 1 set $ 1,080.00
(top up to package item 15, 20ft L top and bottom kitchen cabinets)
2.11 Supply and install 10ft L Samsung Quartz surface kitchen worktop 1 no. $ 960.00
(top up to package item 16, 10ft L polyester base solid surface worktop)
2.12 Supply and install additional 4.5ft L Samsung Quartz surface kitchen worktop 1 no. $ 740.00
General Works
3.1 Supply and install 6ft L x 6ft H 10mm tempered clear glass shower screen c/w swing door 1 no. $ 580.00 at master bathroom
3.2 Supply and install aluminium window grilles in anodised frame for living area L.S $ 720.00
and bedrooms (windows up to 4ft H)
3.3 Supply and install 10mm normal glass windows with sliding 2-way track at service yard L.S $ 380.00 (windows up to 4ft H)
Total Additional Works
$ 11,140.00
Sub-Total : $ 21,828.00
GST $ 1,527.96
Nett-Total : $ 23,355.96
Optional Works (Not included in total for quotation)
1. Construct false ceiling / light holder at bedroom 3 L.S $ 280.00
2. Construct false ceiling / light holder at bedroom 2 L.S $ 280.00
3. Construct false ceiling / light holder at master bedroom L.S $ 380.00
4. Design and fabricate 2.5ft L mirrored door casement storage cabinets 1 set $ 400.00
5. Design and fabricate 2.5ft L suspended casement vanity unit 1 set $ 300.00
6. Supply and install 2.5ft L polyester vanity worktop 1 set $ 270.00
7. Supply and install 10.5ft L x 3ft H 5mm spray paint tempered glass backing between kitchen 1 no. $600.00 top and bottom cabinets
8. Supply and install 3ft L x 7ft H 10mm tempered clear glass casement door at kitchen 1 no. $480.00 entrance using wall hinges
Total Payable Amount
$ 23,355.96 (including GST but not including optional works)
Edited by Ken82
The only thing is the GST part....**** killer....I added on aditioanl items and will raise the quote to about $26 k but maybe about $2k is pay for GST...Haizz....
