Aki0124
15K For A 3Room Bto Budget Tight Or Not?
We had completed a BTO 3-rooms flat at Woodlands Cres for $8.5k
Kindly PM me to get a free quotation at your doorsteps
Items includes:
PROJECT CO-ORDINATING FEES
LAY CORRUGATED CARDBOARD (PROTECTION)
ACID WASH BEFORE HANDING OVER
HAULAGE SERVICES
PAINT WHOLE UNIT WITH NIPPON/ICI WASH & WEAR EQUIVALENT
TO CONNECT INLET AND OUTLET FOR KITCHEN SINK
TO CONNECT INLET AND OUTLET FOR WASHING MACHINE
SUPPLY LABOUR TO INSTALL 2 UNITS INSTANT HEATER
FABRICATE AND INSTALL 17ft TOP & BOTTOM WITH THE FOLLOWING SPECIFICATIONS:
- DESIGNER LAMINATE
- SOFT CLOSING ABS TRIMMING DOORS
- 15MM PLYWOOD CARCASS FRAME & 18MM PLYWOOD DOORS
STAINLESS STEEL DISH RACK
CONSTRUCT KITCHEN CABINET BASE, FRIDGE BASE, WASHING MACHINE BASE
FABRICATE AND INSTALL FULL HEIGHT 5ft CASEMENT WARDROBE WITH THE FOLLOWING SPECIFICATIONS:
- DESIGNER LAMINATE
FABRICATE AND INSTALL 3/4 HEIGHT FEATURE WALL WITH WITH THE FOLLOWING SPECIFICATIONS:
- DESIGNER LAMINATE
FABRICATE AND INSTALL TV CONSOLE WITH THE FOLLOWING SPECIFICATIONS:
- DESIGNER LAMINATE
FABRICATE AND INSTALL FULL HEIGHT 6ft CASEMENT WARDROBE WITH THE FOLLOWING SPECIFICATIONS:
- DESIGNER LAMINATE
SUPPLY AND INSTALL 2 UNIT ALUMINIUM BI-FOLD DOORS AT BOTH TOILETS
Edited by Snorlax85
Items includes:
HAULAGE SERVICES
- DESIGNER LAMINATE
- DESIGNER LAMINATE
- DESIGNER LAMINATE
- DESIGNER LAMINATE
- DESIGNER LAMINATE
Please pm your contact nos.
Hi I personally feels your $13k should be enuff for 3rm BTO. I did my 4rm BTO for less then $10k. hope this helps.
Cheers.
Hi, can PM me your ID/contractor contact details? Thanks.
Price varies depending on what are your needs and requirements. I have rec. quotations from 8k to 30k for 3rm BTO. End up after 5-6 ID, i learn to know which ones are okay which ones ain't.
Choose 1 you trust more.
