Pelect 3 Report post Posted May 31, 2014 If you want to be safe and precise, find out first what is the power consumption (kW) for each of the device. Share this post Link to post Share on other sites
RCT 1 Report post Posted June 9, 2014 (edited) I think you also should see if the cable install can handle the load.. For example 2.5 mm2 cable can only withstand 16-18 A. I also recommend CCM.. Very good price imo.... Even brand like schneider is quite reasonable... Bought Schneider Pieno Series socket and switch for my whole house.. Cost around 300+... Could be cheaper if not for the dimmer unit... each dimmer unit cost $42/- and I bought 4 Edited June 9, 2014 by RCT Share this post Link to post Share on other sites
JL Lin 1 Report post Posted July 9, 2014 Hi all,I needed help again.My kitchen had a 2 x 13a socket point.I think my electrician had tap supply from there to another create 3 x 1 Gang for microwave, oven & hood.As I worried that normal 1 gang switch might not be able to handle individually, so I had bought 3 x 20ax double pole switch (Legrand) aka as water heater switch instead.May I know is this safe for this setup combination and can the "water heater switch" be use for the 3 appliances above instead of normal 1gang switch ? TIA... Share this post Link to post Share on other sites
ngcc76 0 Report post Posted November 3, 2014 I think you also should see if the cable install can handle the load.. For example 2.5 mm2 cable can only withstand 16-18 A. I also recommend CCM.. Very good price imo.... Even brand like schneider is quite reasonable... Bought Schneider Pieno Series socket and switch for my whole house.. Cost around 300+... Could be cheaper if not for the dimmer unit... each dimmer unit cost $42/- and I bought 4 Hi,May I know where can get Schneider Pieno Series socket?Thanks. Share this post Link to post Share on other sites
