davidboh
Cost To Hack Down Wall?
Hi does anyone know the indicative cost to do the following work?
1.) Remove half of the wall between 2 bedrooms? I intend to demolish the upper half of the entire wall and replace with glass.
2.) How much will it cost to change the walls of a standard HDB toilet into full glass? And how much for half glass?
Thanks in advance.
hi david,
it depends on the length that u are removing. also are u doing other works? if no, hackers will charge a bit higher (think economies of scale)
secondly, change the wall? u mean hack the wall and install glass partition?
Means my toilet will be pure glass without concrete walls. Also I am intending to redo the entire place just contemplating if i shld be hacking walls
