Mon56
Id Vs Contractor Quotes, Please Help
Hi All,
I've been through all the renovation forum included Renotalk and Hardwarezone, but I'm still having a little bit confusion with the quotes as I can see they playing around with the prices (lower one things and raise the other). With that said following is my quotation from my ID or contractor. Please share with me your experience and insight.
ID
HACKING, HAULAGE & PRELIMINARY WORKS
Hack Existing Floor Finishes at 2x Toilets
Hack Existing Wall Finishes at 2x Toilets
Hack All Existing Gypsum Board & Door Frame **** Area
Hack Existing & Dispose 2x Ledges **** Area
Hack Existing & Dispose Wardrobe at Master Bedroom
Hack Existing & Dispose Glass Sliding Door Master Bedroom
Hack Existing Built-in Basin at Kitchen
Hack & Trim Existing Wall Between Common Toilet & Kitchen
Dismantle 2x Ceiling Fan
Construct New Wall using Hollow Block to Seal Up Previous Common Toilet Entrance w/ Cement Smooth
Supply & Laying Corrugated Paper (Single Layer) as Floor Protection
Haulage of New & Raw Materials
Clearing of Debris
Total Hacking, Haulage & Preliminary Works Cost :$3,500.00
WET WORKS
MASTER TOILET
Supply & Lay Homogeneous Floor Tiles
$580.00
> Selection of Tiles: Up to $3.00 psf / Up to 300x300mm
> Includes: Waterproofing
Supply & Lay Ceramic/Homogeneous Wall Tiles $ 1,750.00
> Selection of Tiles: Up to $3.00 psf / Up to 300x600mm
> Excludes: Border/Special Tiles
Construct Tiled Cement Door & Shower Kerb$240.00
COMMON TOILET
$550.00
$1,600.00
$240.00
LAMINATE FLOORING
Supply & Install 8mm SUPREME Laminate Flooring at Master Bedroom (Includes: Skirting)
$800.00
CEILING WORKS
Construct False Ceiling w/ False **** & Master Bedroom
$1,200.00
PAINTING WORKS
Painting Works for Whole Unit
$1,600.00
> FULL RANGE of Paints from DULUX/NIPPON
Apply Sealer Before Painting
$500.00
PLUMBING WORKS
Supply & Connect Single Stainless Steel Piping for 2x Toilets (for HDB Exposed Piping Only)
Supply Labour to Install 2 sets of W.C. Bowl
Supply Labour to Install 2 sets of Wash Basin
Supply Labour to Install 2 sets Toilet Accessories
Labour to Install 2 sets of shower Head Set
Labour to Install 2 sets Bathroom Bidet Spray
Labour to Install Storage Tank Heater
Supply & Connect 2x Hot Water Points from Storage Heater
Total Plumbing Cost :$1,500.00
OTHER WORKS
Supply & Install 10mm Clear Tempered Glass Shower Screen at Toilet (L1500mm x H1800mm) (1 Fix & 1 Swing)
$400.00
> Exclude: Over Head Supporting Bar for Shower Screen
Supply & Install 10mm Tempered Clear Glass as Fix Panel at Common Toilet
$150.00
Supply & Install Bi-Fold Door at 2x Toilets (Aluminum Frame w/ Acrylic Panel)
$500.00
Washing of Whole House
$450.00
Total before GST:
15,060.00
GST 7%:
1,054.20
Total after GST:
16,114.20
CONTRACTOR
A Demolition Works
1 HDB Renovation Permit Application & Processing F.O.C.
2 Demolish a doorway permit F.O.C.
3 Hack a doorway at common toilet 300
4 Hack existing wall tile at 2 toilet 600
5 Hack existing floor tile at 2 toilet 500
6 Hack existing skirting at main bedroom 150
7 Dismantle existing partition at future room 350
8 Remove existing toilet bowl,basin & door F.O.C.
9 Dismantle existing vanity at kitchen 150
10 Dismantle existing wardrobe & aluminiun sliding door at main toilet 300
Sub-total 2350
B Masonry Works
1 Labour to construct hollow block to seal existing doorway at common toilet 480
2 Labour to make good existing skirting at main bedroom 200
3 Supply & lay wall tile to make good existing vanity area 300
4 Supply & lay wall tile to make good existing common toilet 650
5 Supply & overlay laminate flooring c/w skirting at main bedroom 950
6 Supply & lay ceramic wall tiles till ceiling height at 2 toilet 2400
7 Supply & lay non slip homogeneous floor tiles at 2 toilet 1000
8 Supply & lay waterproofing membrane at 2 toilet 400
9 Construct 2 nos, shower kerb 160
Sub-total 6540
C Ceiling Works
1 Supply & install false ceilling **** 700
2 Supply & install false ceilling at main bedroom 850
Sub-total 1550D Plumbing Works
1 To run copper piping for 2 toilet (Cold water) 880
2 Labour to install bathroom item 750
3 To run outlet pvc piping for 2 toilet F.O.C
Sub-total 1630
E Door / Glass / Windows
1 Supply & install 1 nos sliding tempered shower screen at common toilet 750
2 Supply & install 1 nos swing tempered shower screen at main toilet 550
3 Supply & install 2 nos,aluminium bi-fold doors at 2 toilet 500
0 1800
F Painting Works
1 Paint whole house exposed wall & ceiling with ICI/Nippon emulsion paint 1000
2 Varnish/Paint all doors, door frames & exposed pipes 300
Sub-total 1300
G Miscellaneous Works
1 Whole house chemical wash 280
2 Provide haulages & debris clearing services 550
3 Lay protection sheet at affect area F.O.C
Sub-total 830
H Electrical Works
1 Electrical aprox 500
Sub-total 500
Total 16500
Edited by Mon56
The ID charges u GST and does not include the electrical work in the quote, ask for a more itemised quote from your ID ?
No GST from the contractor, the haulage fee from the contractor seem abit high ? How come there is 750 quote for installing bathroom items ? what are you installing in your bathroom?
Lastly, please do not take my comments seriously as i am a noob. According to the ID doing my house, the haulage fee is charge by the town council or etc, there will be a receipt stating the amount.
Edited by lookaround
Yeah, I've found out haulage fee is supposed to be around $215 and provided by city council but It was the post on 2007 on this renotalk so I'm not sure what is the current price now.
Bathroom item such as W.C, Sink, etc
