2359 0 Report post Posted May 4, 2014 (edited) HiAppreciate your opnions on below quotes.Personally, I find the items in red a little high, esp for the floorings and kitchen solid surface.- Can anyone advise why the kitchen floorings are rather pricely?- For the price of the vinyl flooring, I think could have done HERF (Evorich) by topping up another $400.Thank you.(A) General Works 1 Supply labour & materials to carry out the following works:-a Dismantle & dispose existing cabinet at kitchen $250b Dismantle & dispose existing partitional wall, door and door frame along passageway $100c Hack off existing sink & cooker stove at kitchen $450d Hack off existing skirting ****/dining hall, passageway and 3 bedrooms $350e Hack off existing fridge base at kitchen $50f Hack off wall (1/2 ht) between living hall and kitchen $100g Dismantle & dispose existing sliding door, 2 sets nako window and door frame between kitchen and yard area $100h Loading of renovation materials $150i Clear debris throughout and after renovation $200j Chemical wash and general cleaning upon handing over $250(B) Masonary Works 1 Supply labour & materials to carry out the following works:-a Overlay homogenous floor tiles ($3/sqft) for kitchen and service balcony $1950 ($15 psf)b Construct 50mm Ht motar base with side tilings for cabinet (est 4ft length) and repair existing existing cabinet base after hacked at kitchen $500c Construct 50mm Ht motar base with full tilings for washing machine (est 2ft x 2ft) at kitchen $150d Construct 50mm Ht motar base with full things for fridge (est 800 x 700)mm at kitchen $150e Make good,plaster smooth and replace wall tiles (matching or similar) at hacked wall area between living hall & kitchen and kitchen & yard area $500f. Make good and plaster smooth hacked skirting area for entire unit $250g. Cut out groove for washing machine outlet pipe, apply water proof membrance, lay PVC outlet pipe and box-up with full tilings at yard area $2502 Supply labour & materials to replace tiles for door step at main entrance (If required) $180© Vinyl Floor Works 1 Supply labour & materials to apply self levelling compound and lay 2.5mm thk vinyl flooring for living/dining hall, passageway and 3 bedrooms $5130 ($5 psf with 10% buffer as wastage)2 Supply labour & materials to install solid wooden skirting for living/dining hall, passageway and 3 Bedrooms $1500, 6 per ft(D) Plumbing Works 1 Supply labour & materials to carry out the following works:-a Install hot pipe for wash basin at master and common toiletb Install inlet & outlet pipe for washing machinec Install sink,tap, inlet and outlet pipe at kitchen (sink & tap by owner)650.00(E) Aluminum Window/ Metal Works Green tinted casement windows with white horizontal grills ($340/m)MBR 2.4m $ 810Bedroom 1 1.3m $ 450Bedroom 2 1.3m $ 450 Install alum windows (WPC) c/W acrylic panel sliding door at kitchen entrance $300(F) Painting Entire house with ICI/ Nippon paint (103 sq metres) $1600Oil paint for main gate/ door, 3 bedroom and store doors $480(G) Carpentry Kitchen ($230/ft)18ft top/ bottom cabinet with laminate finish, c/w ABS edging, soft close hinge $41401 alum frame frosted glass door1 SS dish rack1 cutlery tray1 drawerSolid surface (12ft) ($75/ft)9] $1725 Living RoomFull ht feature wall panel (2.5m x 2.4m) using plywood backing $1550laminate finish (1m ht at bottom)3 panels of 5mm clear mirror (at top)35] Wall Hung bottome TV console with laminate finish (8ft) ($130/ft)9] $1040 Full ht L shape storage cabinet (12ft) with laminate finish ($230/ft) $2760Bedroom8ft top hung cabinet with study table with laminate finsh c/w BS edging ($220/ft) $1760 (H) Partition False Ceiling at MBR (120 sq ft) $618 ($3 psf) False Ceiling at Bedroom (110 sq ft) $435, $3 psf ($3 psf)Box-up to flush living room wall (160 sq ft) $736 ($4 psf)Glass work8]($30 psf?)6mm white tampered glass backing between top/ bottom cabinets in kitchen $700Electrical Works 2 x 13 A power pt $701 x 13 A power pt $60SCV pt $100Light pt $35Tel pt $55Heater pt $110Install light fitting $10Install hanging light/ fan $30Relocate any of above $35Total without electrical works $34 000 Edited May 15, 2014 by 2359 Share this post Link to post Share on other sites
Dylanchua 9 Report post Posted May 5, 2014 Way too expensive.. I'm shortlisting my quotes down to 2 IDs and both are giving me $110-$120 per foot for kitchen cabinet. One of them is quite reputable here in the forum too.Solid surface price is always 2 digits only (per foot).. You can get yourself IQuartz or granite with $140 per ft and still have a lot of spare change for beer. Share this post Link to post Share on other sites
2359 0 Report post Posted May 5, 2014 HiFor kitchen cabinets, trust this equates to $220 - 240 per ft for top/ bottom?For solid surface, the figure is $75 per ft after clarification on the length.Will anyone like to comment on the price of the flooring, thanks Share this post Link to post Share on other sites
trexis 0 Report post Posted May 13, 2014 Hey,Yeah the flooring is kinda expensive. Possible to state the brand? Yeah evorich flooring would be ideal but there are pros and cons. Pm me so I can share with you. Share this post Link to post Share on other sites
2359 0 Report post Posted May 13, 2014 HiThere are no brands given yet, pls do share the pricing for your floorings Share this post Link to post Share on other sites
kangeroo168 10 Report post Posted May 13, 2014 yes, flooring is expensive. can recommend u lower price ones.wood skirting---what? wood skirting needs $1,500??? u sure or not???vinyl floor tiles -- yes, its a bit overpriced.. what is the brand?featurewall-- slightly higher, u can maybe shave off $100-$150solid surface-- i find it quite reasonable, only if u are getting the 'shiny/glossy' type, as they tends to be more expensive.glasswork--slightly higher, can shave a bit offthese are all my suggestions. Share this post Link to post Share on other sites
2359 0 Report post Posted May 13, 2014 Thank you for the suggestion. How much would you recommend the skirting, glasswork, partition and windows to be shaved off? Share this post Link to post Share on other sites
fsuz 2 Report post Posted May 13, 2014 The painting seems quite expensive too.. you may want to ask your contractor to specify the number of colours allowed and the range you can choose from.. the amount you are paying for for the oil paint on top of the wall paint seems too ex.. Also, i assume you do not need a sealer coat for the wall? Share this post Link to post Share on other sites
fsuz 2 Report post Posted May 13, 2014 Oh and forgot to add.. for the carpentry, only one drawer or one set of drawers is included in the $230/ft run he quoted you? 1 drawer seems too little and it may mean that he will charge you extra for additional drawers.. Share this post Link to post Share on other sites
2359 0 Report post Posted May 15, 2014 Ok. Some updated quotesSolid skirting at $6 / ftFalse ceiling at $3 psfAll details updated in first post.Saw this paint online. . Dulux Light & Space, has anyone used it before? Supposed to reflect twice as much lights in the walls Share this post Link to post Share on other sites
