DeAnneCo
Indoor & Outdoor Water Feature, Wall Fountain, Aquarium, Bubble Wall, Waterfall
New product from UK and its new to Singapore! Developed exclusively for water feature cleaning and fountain maintenance. As the name implies, this new generation water feature cleaner 'Fountain Safe' will help you to effortlessly maintain the lustre of your shiny new water feature whilst ensuring that the safety of your children and pets is not compromised.
  • Non-Toxic/Non Abrasive
  • Safe for children, pets and even fish
  • For use with both indoor and outdoor water features (even ponds)
  • Cleans and protects
  • No unpleasant odour - unlike most water feature cleaning products available
  • Easy to use, eliminating the need for maintenance of all our water features
  • Helps to prolongs pump life
Simply add two capfuls (depending on the size of the feature) to the reservoir or pebble pool and the active formula will protect and clean, preventing all common forms of algae growth and slime. Two capfuls treats up to 25 Litres of water for one month. Each container contains 98 grams, enough product to treat a total of 75 Litres of water.
Edited by DeAnneCo
Feng Shui Rotating Sphere Fountain (Genuine Crystal Sphere is available as optional item).
Make a statement of creativity and class all rolled into one beautiful floor standing piece.  This fountain is a classy and elegant piece that will leave your guests with admiration. This fountain is spectacular. Sunrise Springs is just that, the perfect mix of sight and sound to balance your environment.
Sunrise Springs Faux Marble Crystal Sphere Floor Standing Water Fountain
(Size: L35.5cm x W35.5cm x H129.5cm)
Edited by DeAnneCo
Victoria Falls Cascade Stainless Steel Floor Fountain - Anodizing Black Polished
Size: L32cm x W42cm x H100cm
This stunning contemporary water feature is first ever to be seen in  anodizing  black polished surface made from grade 304 stainless steel material. This brilliantly designed piece  will without doubt  add a crisp, modern edge to your home, office or even for outdoor. Watch how the water cascades out of its spillway blade with NO SPLASH into  self-contained  reservoir, creating a relaxing sound from the waterfall. Integral white LED lights further enhance the appearance of the feature and enable you to enjoy the soothing effects of the fountain throughout the day or night.
  • Manufactured from the finest grade 304 stainless steel
  • Is made of has a high nickel content, which makes it highly resistant to corrosion and easy to maintain
  • Fully anodizing black polished surface
  • Hand crafted workmanship
  • Fully self-contained, easy to set up, add water, plug in, switch on and require no plumbing
  • Variable water-flow speeds; can adjust the water flow to fit your mood
  • Integral White LED lights further enhance the appearance
  • Decorative pebbles included
  • Rated for indoor or outdoor use
  • 1 Year Limited Warranty on LED Light, Pump & Transformer
  • L32cm x W42cm x H100cm
  • Grade 304 / 316 / 316L full stainless steel in brushed, chrome mirror polished, powder coated glossy white, glossy black, matt black or powder coated sandstone finish at your choice, subjected to the availability of the material
  • Customisation and flexibility with this water feature, allowing our customers to choose both sizes and colors to suit your requirement
Edited by DeAnneCo
Dalton Tier Floor Standing Water Fountain Size: L36cm x W24 x H84cm
A modern multi-tiered design with multiple streams of water flow creates a relaxing and meditative atmosphere for your indoor, outdoor spaces, garden areas, or porches with this contemporary fountain in a beautiful stone finishing. Water gently flows down each tier in a relaxing display with LED illumination. It is a sharp addition to any decorative setting whether indoors or outdoors.
  • Durable fiberglass construction
  • Low voltage transformer (AC Adaptor, IP44 rated), Input 230-240V~50Hz, Output 12V~1100mA 13.2VA (Optional 5m Long Extension Cable)
  • Low voltage WP-650(AC 12V 50Hz ~ 8W) submersible pump with 5m long cable, energy efficient with low running cost
  • Variable water flow speeds; can adjust the water flow to fit your mood
  • Integrated low voltage white LED ring light-1.6W x (3) illuminate the water flows
  • Low voltage that can operates continuously, 24 hours a day, 365 days non-stop
  • Entirely self-contained and portable
  • Easy set up as simply fill up with water, plug in and switch on
  • Rated indoor and outdoor use
  • 1 Year Limited Warranty on LED Ring Light, Pump & Transformer
Edited by DeAnneCo
Bubble Fountains : 4 Reasons to Buy One
One of the most popular and sellable model in U.S. This Floor Standing Wave Bubble Wall - Acrylic Base & Panel is a great way to create a soothing yet trendy ambiance to your home or office without the need for a lot of cleaning or maintenance. Featuring multi-chambered acrylic panels in a modern wave design, this bubble fountain is sure to enthrall you and your guests as the bubbles glide smoothly through the water following the serpentine figure of the panel. Its remote control with programmable colors changing LED lights not only serve to illuminate your space, it can also add uniqueness and variety to the panel making it easy to personalize and create a specific mood. Made with durable cell cast acrylic, the panels are not only incredibly clear but also over ten times stronger than glass.
180cm Floor Standing Wave Bubble Wall - Acrylic Base & Panel
(In ready stock Size: L60cm x W20cm x H180cm) /
120cm Circular Bubble Tube with Remote Control LED Lights - Stainless Steel with Acrylic Panel
Size: Overall: Height 120cm x Width 26cm Tube: Width 12cm Base: Height 21cm x Width 26cm x Depth 26cm (Available 1.80cm)
Edited by DeAnneCo
Size: L30cm x W30cm. Price $16.80 each. Special price for Bulk orders. Pebbles Stone & Turf decking Tile is also available from us. Create a custom decking without spending a fortune. Enhancing the look of your deck and patio is affordable! No expensive contractors, do it yourself with snap-on deck tiles! Just About Anywhere - Perfect for gazebos, balcony, patios, pool sides (non-slippery when wet). Rejuvenate a tired concrete slab or spruce up an old wood deck. These tiles install best on hard surfaces (i.e., concrete, asphalt, wood, etc.), but can also be installed on semi-hard surfaces as such as (i.e, lawn, dirt, or gravel).
Composite Decking Tiles (wood-plastic composites) is an alternative material to traditional solid wood decking. The advantages of composite wood is that it is generally more resilient than solid wood and has good dimensional stability, especially in wet conditions.
This quick interlocking D.I.Y Composite Decking Tiles can be used in a number of ways: as part of garden landscaping, to extend living areas of houses, as an alternative to stone based features such as patios, and can also used it as a base for water feature setting with decorative pebbles around to hideaway the water splash on the floor.
Order online from our website or visit our store to see our displaying show pc.
Edited by DeAnneCo
Our simple interlocking tile system makes it easy for anyone to enjoy the outdoor flooring of their dreams without the hassle, frustrations and hard work of laying tiles the conventional way. Just clip the tiles together, automatically guaranteeing precise spacing, perfect alignment and securely locked in position.
  • No messy adhesives
  • No tedious grouting
    Perfect alignment guaranteed
  • Accurate and precise spacing
  • Consistent tiles heights
Our Natural Pebble Tiles start with hand selected, premium grade pebbles from the beaches of South East Asia. Each pebble is chosen for its flatness, symmetry and color consistency. The pebbles are mounted on a pliable mesh backing using non-toxic, environmentally safe epoxy. When installed using our interlocking system, they produce a designer finish with no detectable pattern.
Our deck tiles can be laid on most solid surfaces such as concrete or existing wood decks, provided the surface is as smooth and even as possible so the tiles dont “rock”.  But other than that, unless you need to cut the tiles to fit around posts or pipes or to fit precisely within a specific shaped area, the only equipment youll need is a tape measure (and a pair of sturdy work gloves).
Easy to Install - Build Pebbles flooring in just minutes! These snap-on tiles have an interlocking design base for easy Do-It-Yourself installation. Attach tiles together with no tools required!  Perfect match and precision spacing between every tile, every time, guaranteed! They are ready to use right out of the box.
Interlocking Artificial Turf Deck Tiles
Easy to Install - Build turf flooring in just minutes! These snap-on tiles have an interlocking design base for easy Do-It-Yourself installation. Attach tiles together with no tools required! No messy glue, no nails, no staples. Best of all, no sodding! Perfect match and precision spacing between every tile, every time, guaranteed! They are ready to use right out of the box.
Create a custom turf floor without spending a fortune. Enhancing the look of your deck and patio is affordable! No expensive contractors, do it yourself with snap-on deck tiles! Just About Anywhere - Perfect for gazebos, balcony, patios, pool sides (non-slippery when wet). Rejuvenate a tired concrete slab or spruce up an old wood deck. These tiles install best on hard surfaces (i.e., concrete, asphalt, wood, etc.), but can also be installed on semi-hard surfaces as such as (i.e, lawn, dirt, or gravel). Low Maintenance No need to water or mow, ever! The PP and PE fibers are fade and mildew resistant. The elevated PVC platform base allows for adequate drainage and moisture ventilation. Looks Like Real Grass! To replicate the look of real grass, our turf uses the top straight fibers are made from UV treated highly fade resistant polyethylene (PE) straight yarn, the color tones and textures replicate the look of real turf. Detailed craftsmanship goes into each of grass turf deck tile.
Jade Pebble Stones size: 3-5cm are naturally created and tumbled in its natural habitat to produce the most smooth and rounded rock for decorating and a very versatile dressing to add the finishing touch to your water feature. You can use them as pebbles or border dressing to surround and complement water features, completely conceal the unsightly water pump electric cable or hide away splashing of water droplet used indoor. They are especially striking when wet as the water brings out their natural beauty.
Natural Jade Pebble Stones overall for good luck. Many cultures, including the Irish, see the color green as a symbol of good luck. Jade's green hue not only looks beautiful, but it is believed that it helps attract good fortune into your life.
The Specific Feng Shui Properties of Jade
In feng shui, Jade has been used for centuries for its abilities to create a serene feeling of harmony and balance. Jade is also used as a protection and good luck feng shui stone. You can find endless good luck feng shui charms with Jade employed for various purposes - from creating wealth to attracting more friends.
Jade is also a popular feng shui application (body feng shui, which is no less important than your home feng shui!). Of course, another reason why Jade has been extensively used in feng shui is because Jade is widely available in China, the birthplace of feng shui.
Edited by DeAnneCo
Maintenance & Fountain Care  -  EasyCare ProTec Scale and Stain Remover
Protecs' powerful Synertec cleaners remove and prevent both white calcium scale-deposits and stains (due to iron and copper) on surfaces of decorative; fountains, birdbaths, tabletop fountains, and water gardens.
The powerful, dual-action formula of Protec makes it very easy to maintain the beauty of water statuary surfaces. Protec contains a unique blend of advanced organo-phosphates for superior protection against both white calcium mineral buildup and metallic stains. Protec will prevent and remove existing mineral deposits and metal stains on all types of fountain and statuary surfaces. This product will also help prevent pump damage due to hard water buildup. Protec treated water is safe for birds, plants, and animals.
Features:
  • Safe for all types of fountain surfaces
  • Recommended dosage: one drop per 38L of water per month- very economical
  • Powerful Synertec cleaners removes and prevents white calcium scale and metal stains buildup on fountain surfaces.
  • Controls water metals and prevents surface stains. Keeps water surfaces continuously clean and looking new
  • Non-acidic, non-hazardous, non-foaming and non-staining. Aggressive non-acidic formula works quickly.
  • Eliminates harsh cleaners and mechanical scrubbing.
  • Protects water pump damage due to hard-water build up and corrosion.
  • Protec eliminates the need for using distilled water in your fountain - it removes the mineral deposits from tap water
  • Environmentally safe.
  • Treated water safe for birds, plants, and animals including aquatic life.
How it works:
Utilizing the newest technology, Protec's Synertec formula contains a highly synergistic blend of organo-phosphonates and copolymers. Protec functions by utilizing several mechanisms involving dispersion, crystal modification and "threshold inhibition." The product's adsorption onto a calcium crystal's site helps weaken, dissolve and prevent further precipitation. Stains are removed and prevented by solubilizing metal ions (adsorption) and dispersed (inhibition).
Maintenance & Fountain Care  -  EasyCare FounTec Algaecide and Clarifier
Fountec's organic polymers keep fountain and statuary water cleaner, clearer, and algae-free without chlorine and laborious scrubbing. This EPA registered product utilizes a unique control mechanism to kill and inhibit algae without harming the environment. Unaffected by heat, sunlight and evaporation, Fountec also outlasts and outperforms copper, enzyme and quat based products. A small dose of Fountec lasts up to a week or more and is very economical due to its concentrated formula. Fountec is non-hazardous, non-staining and non-foaming. Fountec Algaecide and Clarifier is the most effective product now available for fountain treatment.
It is safe for birds, plants, and animals but not for fish. While we don't recommend your fountain as a drinking source for pets, the fact remains that it is hard to keep pets from drinking from it. However, as long as the product is used according to directions, it will not harm your pet. As with all chemicals, we recommend that you keep them out of reach of children and pets.
Weekly Fountec use also prevents mosquito landings! Fountec is not only a powerful algaecide and clarifier, it is also a surfactant that breaks water tension. Due to the natural effect of Fountec's polymers on water tension, it is an excellent deterrent for control of mosquitoes, flies, and wasps in fountains, water gardens and birdbaths.
Fountec® Features
1. Safe for all types of surface.
2. Kills blue, blue-green, yellow, and black algae types - EPA registered.
3. Non-hazardous, non-foaming and non-staining.
4. Does not require regular chlorine usage.
5. Deters and prevents mosquito landings on water.
6. Water is safe for birds, plants, and animals. Fountec's dosage is too stong for fish use.
Benefits:
1. Kills and prevents algae better than other products.
2. Out performs copper, enzyme, and quat-based products.
3. Protection lasts a weeks or more, not days.
4. Eliminates  harsh cleaners and scrubbing.
5. Kids can play with water, dogs and birds may drink ater, plants will not be damaged.
6. One 237ML bottle typically lasts up to one year.
