lookaround
Reasonable Quote ? Any Missing Details ?
  On 8/18/2014 at 7:10 AM, AdNaLoY said:
Hi, May I get the contact for your quote 3? thanks
  On 8/18/2014 at 11:49 AM, joeejy said:
Hi, can pm me the contact for quote 3 ? thank you very much!
PM sent, enjoy ur renovator search
  On 4/28/2014 at 1:54 PM, lookaround said:
In the end, i settle for Quote 3 from a ID.
Wet Works
1 To supply labor and material to construct 2 nos cabinet bases $290.00
2 To supply labor and materials to construct fridge bases $90.00
3 To supply labor and materials to construct washing machines bases $130.00
4 To supply labor and materials to construct shower kerb $70.00
Total Wet Work Cost $580
Plumbing works
1 To supply labor and materials to extend stainless steel piping @ existing HDB copper piping point for new kitchen sink position $180
2 To supply and lay conseal PVC piping for drainage area @ kitchen sink $90
3 To supply and lay conseal PVC piping for drainage area @ washing machine $110
4 To supply labour only to install storage heater c/w storage heater stainless steel piping extension for hot & cold $140
5 To supply labor only to install toilet/whole house accessories FOC
6 To supply labor only to install & connect new kitchen sink & tap FOC
7 To supply labor only to install 2nos mini-spray sets FOC
Total Plumbing works $520
Ceiling/Parition works
1 To supply labor and materials to construct full height 2 sided partition wall c/w wood base board @ foyer area $430
Total Ceiling/Parition works 430
Glass works
1 To supply labor and materials to install full height plain edge clear mirror @ foyer area partition wall $450
2 To supply labor and materials to install designer series full height plain edge strip effect clear mirror @ foyer area partition wall 530
3 To supply labor and materials to install 2 D casement glass door between kitchen partition $580
4 To supply labor and install 1 set tempered glass shower screen @ master bathroom [1pcs fixed , 1casement[ $530
Total Glass works :2090
Aluminium Windows works
1 To supply and install HDB approve standards grade aluminium sliding window grill @ service yard, living/dining & 3 bedrooms/[max height 4 ft][bronze/Silver] $980
2 To supply labor and material to install 1 set powder coated sliding aluminium window @ service yard c/w HDB approved coloured glass. $680
Total Aluminium works $1660
Electrical works
1 To supply labor only to install internal light fixtures @ HDB standard ceiling light points(13 lighting points,lighting provided by owner) FOC
Total Electrical works $0
Carpentery works
Foyer Area
1 To fabricate and install full height shoes cabinets c/w casement door, ABS trimming, soft close mechanim hingers and designers handler in laminate finish[est 3ft] $650
Living Room
2 To fabricate and install low height storage cabinets daybeds c/w PVC cushion, casement sling door, ABS trimming, slow close mechanism hindges & designer handles in laminate finishes [est 10.5ft] $1470
Master Bathroom area
3 To fabricate and install suspended storage cabinets c/w 1 sliding mirror door, top and bottom coverlight , internal shelving, ABS trimming and designer handles in PVC finishes [est 5 ft] $690
Kitchen Area
4 To fabricate and install top tread removable pelmet box up in laminate finish @ both side 700
5 To fabricate and install top & bottom kitchen cabinet c/w ABS trimming, slow close mechanicsm hindges, 2 set of drawers and designer handles in laminate finish[est 20 ft] $2000
6 To supply and install 1 no frosted glass for kitchen cabinet FOC
7 To supply and install 1 nos 2-tier stainless stell dish rack FOC
8 To supply labor only to install cooker hob and hood FOC
9 To supply and install1 no PVC cutlery tray
10 To supply and install polyester base heavy duty solid surface worktop c/w front profile & backsplash [est 17ft][Test and appoved by PSB] 1150
*All carpentry works are all using solid 3 plywood c/w high pressure laminate finish, use only local laminate materials, material quality assured
Total carpentry costs=6660
Misc works
1 To supply labor and materials to pain whole unit using Original Nippon/ICI paint [4+1 colors] include Matex paint for ceiling (min two coats), painting of all PVC/stainless steel pipes, all doors, door frame c/w glossy paint if needed, main gaite c/w glossy paint if needed $1060
2 To supply labor and materials to acid wash for entire unit FOC
3 To supply labor and materials to do general cleanin for entire unit FOC
4 To supply labor and materials to lay corrugated paper for whole house by HDB haulage FOC
5 HDB parking of skip tank at loading and unloading fees FOC
6 HDB Permit and handling fees FOC
7 Haulage and debris removal fees [include upload of sand] As charged as per receipt
Total misc work :$1060 + ?
Total renovation cost = $13000*
* does not include haulage and debris removal fee and additional electical routing.
Hi, can you pm me the ID and renovation company details please? i am sourcing for quotations for comparison too.. thanks!
Hi guys anyone can send me the ID for no 2 and no 3..
my collection of keys is 4th october 2014
costa ris 4 room BTO premium wif floorings from hdb.
Appreaciate if anyone can email it to me at@
ismail_hmzh@yahoo.com.
Thank you so much.
