xibi
First Quote
hi All,
I received this quote from a ID. But i am still trying to see what i have miss, and need to compare more before i could decide. Probably need you guys help.
A Professional Services
1 Design consultation & site co-ordination INC
2 Space planning layout plan INC
3 Design proposal of 3D visual drawing INC
4 Proposal of materials & color INC
5 5 years warranty after sales service INC
B MANSONRY
1 Construct cabinet base with side tiles
2 Construct washing machine base with full tiles
3 Construct shower kerb complete with full tiles at MBR
C PLUMBING
1 supply labour to install/connect
- 2 bathroom accessories
- 2 panels of mirror
- sink outlet & inlet
- heater point to existing point
D GLASS WORK
1 Supply and install 1 set of 10mm tempered glass shower screen at MBR
E MISC WORK
1 supply & paint whole house wall and ceiling using NIPPON emulsion paint (5colors)
2 chemical washing upon completion of works
3 provide corrugated paper for protection
4 HDB renovation permit
F HARDWARES & ACCESSORIES
1 1 set of EF glass/stainless steel cooker hob and hood
2 1 set of monic double bowl kitchen sink and tab
3 1 NOS X MAGNUM storage heater tank 30L
4 2 set X CRIZTO bathroom accessories
G CARPENTRY WORKS
1 design and fabricate & install (21ft) top and bottom kitchen cabinet complete with laminate material inclusive of
- ABS trimming
- 45* recess handle
- internal coloured PVC carcass
- 4 set of blum *BLUMOTION" runner track drawers
- blum soft closing hinges
- 1 set of stainless steel dish hanger
- 1 set of aluminium frame glass panel for dish drainer
2 Supply labor & materials to install (11ft) QUARTZ surface kitchen worktop complete with 50mm backsplash
3 Design & fabricate & install (5ft) full height shoe cabinet complete with laminate material inclusive of
- 2 tone laminate
- 45* recess handle
- ABS trimming
- Open pelmet with laminate finish
- Wooden backing with laminate finish
H DOOR
1 Supply labor & materials to install 03nos X Solid veneer door for MBR, BR2, BR3, kitchen
2 Supply labor & materials to install 02nos X BA/NA aluminium bi-fold door for Bath1, bath2
I WINDOW
1 Supply labour & material to install 3tracks aluminium BA/NA window panels in Service Yard
J Floor works
1. Supply labour & material to install EVERICH high end resilient flooring for living room, MBR, BR2, BR3
total cost: 21k
Edited by xibi
  • Like 1
Would you good that state the pricing individual. One lump sum is hard for us to see which area is more expensive.
Likewise on what you had mention anything you had miss. Would be good you write down a list that you need for your renovation. Do not engage an ID or contractor without knowing what you want to do. As if there is any additional things need to be done in the midst of renovation then will affect the flow of the schedule of the renovation and more charges will be credit in.
So do a list on what you want to do and then try to get quotation from various IDs and contractor.
