messi1986
Reasonable Quote For Hdb 4 Room Premium?
Hi all would like to have some advice on the mentioned quote. First timer owning a house so so very experience. Hope experts here can help and give advice.
Living/Dining & Passage Way
Supply & install 04 slanted shelves using solid plywood in white PVC finishing on existing cabinets at dining.
200
Supply & run 14 down light electrical points for L-box light holder ****/dining, works includes labour to install lights.
(Lights to be provided by owner)
930
Supply & install L-box light holder ****/dining.
(Excludes sealant & painting)
(Based on 78 feet length)
620
Supply & install full height partition wall with wood support for wall mounted altar.
(Based on 4 feet length)
235
Supply & shift existing double power point, TV point & telephone point to be hidden inside TV console ****.
255
Supply & install full height feature wall using solid plywood in laminate finishing ****.
(Based on 6 feet length)
1020
Supply & install suspended TV console comes with middle glass panel soft closing swing doors using solid plywood ****, external in laminate & internal in white PVC finishing.
780
Supply & install fixed horizontal invisible grills ****.
(Based on 12 by 3 feet length)
465
Supply & run 02 down light electrical points for U-box light holder at passage way, works includes labour to install lights.
110
Supply & install U-box light holder at passage way.
(Based on 16 feet length)
190
Sub Total:
4805
Main Bedroom
Supply & run 08 down light electrical points for L-box light holder, works includes labour to install lights.
600
Supply & install n-shape L-box light holder.
(Based on 38.5 feet length)
305
Supply & install false ceiling.
(Based on 26 square feet)
100
Supply & install full height sliding wardrobe using solid plywood, external in laminate & internal in white PVC finishing.
(Based on 7.5 feet length)
1800
Supply & install wall mounted dressing table with drawer using solid plywood, external in laminate & internal in white PVC finishing.
(Based on 2 feet length)
240
Supply & install 5mm clear beveled mirror on wall.
(Based on 2 by 4 feet length)
95
Supply & install fixed horizontal invisible grills.
(Based on 10.5 by 3 feet length)
415
Sub Total:
3555
Bedroom 2
600
(Based on 37.5 feet length)
300
(Based on 15 square feet)
60
(Based on 4.5 feet length)
1080
(Based on 9.5 by 3 feet length)
375
Sub Total:
2415
Bedroom 3
600
300
60
(Based on 5 feet length)
1200
375
Sub Total:
2535
Kitchen
Supply & extend existing water inlet piping.
80
Supply labour to construct L-shape cabinets base in cement smooth surface & skirting in tiles finishing.
(Tiles to be provided by owner)
(Excludes HDB appointed haulage services)
(Based on 14 feet length)
280
Supply & install top cabinets using solid plywood, external in laminate & internal in white PVC finishing.
Item includes:
-Swing doors in ABS trimming
-01 silver aluminium frosted glass panel door
-Soft closing hinges for swing doors
(Based on 12 feet length)
1380
Supply & install L-shape bottom cabinets using solid plywood, external in laminate & internal in white PVC finishing.
Item includes:
-A set of 03-04 drawers
-02 pull-out tray for oven & microwave
1680
Option A:
Supply & install box-up using solid plywood in granite top comes with 50mm backsplash finishing.
(Based on 5.5 by 0.5 feet length by 0.5 feet height)
465
Supply & install double bull nose granite table top comes with 50mm backsplash.
1750
Option B:
Supply & install box-up using solid plywood in iQuartz i series top comes with 50mm backsplash finishing.
660
Supply & install iQuartz i series table top comes with 50mm backsplash.
1820
Supply labour to install kitchen sink, water tap, connect water inlet & outlet.
(Items to be provided by owner)
120
Supply & install 10mm half clear half frosted tempered glass swing door comes with kitchen wording design.
(Based on 3.5 feet length by 7.5 feet height)
850
Supply labour to install cooker hood & hob.
FOC
Supply & install a set of PVC utensils tray.
FOC
Supply & install a set of stainless steel dish drainer.
FOC
Sub Total for Option A:
6605
Sub Total for Option B:
6870
Bath/WC 1
Supply labour to construct shower kerb in tiles finishing.
(Based on 5.5 feet length)
120
Supply & install white powder coated aluminium sliding shower screen in colour acrylic panels finishing.
(Based on 5.5 by 6 feet length)
380
Supply & install suspended vanity cabinets with soft closing doors using solid plywood, external in laminate & internal in white PVC finishing.
240
Sub Total:
740
Bath/WC 2
120
Sub Total:
120
Service Yard
Supply & run stainless steel hot & cold water piping for gas heater to bath/WC 2.
320
Supply & install silver aluminium sliding windows.
(Based on 8 by 4 feet length)
480
Sub Total:
800
Description of work scope
Amt(S$)
Others
Supply & install 10K BTU system 3 Mitsubishi Starmex inverter air-conditioner.
3000
Provide chemical acid washing on tilings & general cleaning before handover.
FOC
Supply & lay corrugated cardboard on existing flooring.
FOC
Sub Total:
3000
Renovation Amount for Option A:
24575
Renovation Amount for Option B:
24840
It is better to get more quotes from other ID and compare.....air-con is way too expensive other can't tell.
Usually system 3 Mitsubishi Starmex inverter how much?
