Vct
My Quotation (4 Rm)
Ok, finally my turn after viewing so many quotation from others here. Feel free to input your 2 cents, 3 cents, 4 cents worth on my quotation. Long story short: (I think my reno work is almost an overhaul of the whole flat)
(4 Room Resale flat)
HACKING & HAULAGE $850.00
Dismantle & Dispose of All Existing Windows
Dismantle & Dispose of Existing 2x Toilets' Sanitary
Wares & Fittings
Haulage of New & Raw Materials
Clearing of Debris
Dismantle & Dispose of 2x Toilets Bifold Door
HACKING OF WALL(s) (Subject to Approval) $550
Hack Existing Wall(s) at Study Room & Master
Bedroom 11 ft
*IF HDB requires QP to Endorse, Endorsement Fee is excluded
CEILING WORKS (*Subjected to Design changes) $2,900.00
Construct False Ceiling/Light Boxes/ Light Holders at
Living/Dining Room/Kitchen/Master/Common/Kids Bedroom
VINYL FLOORING $3,450.00
Supply & Install vinyl Flooring ****/Dining
Room (Includes: Skirting) 250 sqf
Supply & Install vinyl Laminate Flooring at 3x
Bedrooms (Includes: Skirting) 400 sqf
Includes: Raw Material & Labour for Level Screed
PRELIMINARY WORKS $400.00
Make Good Existing Doorway/Opening at Corners &
Plaster Smooth at All Entrances 3 area
Construct Tiled Cement Base (Sides Only) for Kitchen Cabinets 1 area $200.00
Supply Labour to make Good Opening & Install New $240.00
Rubbish Chute at Kitchen
Construct New Wall w/ Hollow Blocks & Plaster $550.00
Smooth at Master Bedroom w New Entrance Position 7 ft
Supply Material & Labour to Lay Pebble Wash at Foyer Area $600.00
WET WORKS
KITCHEN
Supply Raw Materials & PlasterSmooth (Paint) Finish at Wall $1,100.00
(Selection of Tiles: Up to $3.20 psf/ Up to 300x600mm)
Exposed Wall Areas Only (Excludes: Area behind Kitchen Cabinets)
Supply & Overlay Homogeneous Floor Tiles 180 sqf $1,170.00
(Selection of Tiles: Up to $3.20 psf/ Up to 600x600mm)
Includes: Waterproofing
COMMON TOILET $1290.00
Supply & Overlay Ceramic/Homogeneous Wall Tiles 200 sqf
(Excludes: Border/Special Tiles)
Supply & Lay Homogeneous Floor Tiles 50 sqf $400.00
MASTER TOILET $1,290.00
Supply & Overlay Homogeneous Floor Tiles 50 sqf $400.00
Includes: 10% Tiles Wastage
CARPENTRY WORKS $700.00
FOYER / ENTRANCE AREA
Supply & Install Full-Height Shoe Cabinets 3 ft
Supply & Install Bench-Seat w/ Drawers (Includes: Cushion) 3 ft $300.00
LIVING ROOM
Supply & Install Full-Height Feature Wall includes TV Console 6 ft $1,400.00
KIDS BEDROOM
Supply & Install Built-In Full-Height Wardrobe w/
Laminate Swing-Doors (Interior: White PVC) 4 ft $830.00
MASTER BEDROOM
Supply & Install Built-In Pole System Wardrobe c/w
Hanger bar/Shelves/Drawer units 12 ft $2,000.00
Includes: Simple Frame for TV Unit Carpentry to hide wires
KITCHEN $2,300.00
Supply & Install Top/Bottom/Full Built-In Kitchen
Cabinets - High-Quality E.D.L Laminate Doors w/
ABS Trimmings (Interior: White Polykem) 20 feet
Includes: Soft Closing Hinges
Includes: Choice from FULL RANGE of E.D.L
Laminates (Excludes: Metallic Laminates)
Includes: Complimentary TURBO Cooker Hood & Glass Hob Package
Supply & Install SOLID SURFACE TOP 10 feet $600.00
Includes: Standard Back-Splash & Single Profiling
PAINTING WORKS $1,000.00
Painting Works for Whole House 1 area
FULL RANGE of Paints from DULUX/NIPPON
Note: Painting Works is Subject to Max. of 2-3 Coats. Any additional
coat(s) OR surface preparation required due to condition of wall(s) will
be charged based on On-Site Assessment.
ELECTRICAL WORKS
Supply & laying electrical works (Provisional sum) TBC
DOORS/WINDOWS $3300.00
Supply & Install Aluminium Casement Windows at
Living/Bedrooms/Kitchen & Sliding Grilles (Horizontal
Design) (Silver Aluminium) at Whole House
Supply & Install Veneer Hollow Wood Door & Standard $750.00
Door Frame at 2x Bedrooms 2 nos
Supply & Install Non-Fire Rated Veneer Main Doors $850.00
c/w Door frame (Solid Core) w/ Lever Lockset 1 nos
Supply & Install Wrought Iron Main Gate (White Powder-Coated) w/ Lockset $600.00
GLASS WORKS
Supply & Install 6mm Tempered Glass BackSpray $580.00
painted at Kitchen BackSplash
Supply & Install 10mm Clear Tempered Shower x 2 $1,500.00
Screen c/w Sliding Door at Common & Master Bathroom 2 nos
Supply & Install 10mm Clear Tempered Glass Swing $1,200.00
door & Fixed Panel at Kitchen Entrance
PLUMBING WORKS
Supply & Connect/Re-Locate Kitchen Sink Water Point 1 nos $80.00
Supply & Connect/Re-Locate Washing Machine Water Point 1 nos $80.00
Labour to Install Central Water Heater (Includes New Piping)1 nos $150.00
Labour to Install RainShower Mixer & Shower Set at 2x Bathrooms 2 nos $250.00
Labour to Install Kitchen Sink & Mixer 1 nos $100.00
Labour to Install Toilet Wash Basin & Mixer 2 nos $200.00
Labour to Install Pedestal W.C.. 2 nos $260.00
Labour to Install Bathroom Accessories (5 pcs) 2 lots FOC
OTHER WORKS
Supply & Laying of Floor Protection w/ Corrugated FOC
Paper (over new flooring) 1 lot
Washing of Whole House (Twice: 1 Acid Wash + 1 General Cleaning) 1 lot $400.00
Total: After Discount $31,888.00
This quotation is one of the reasonable one i received and FYI, it's from a contractor not ID.
PS: Please do not ask which contractor as i have yet to start my reno, therefore unable to justify their work.
Edited by Vct
see comment as below.
Are your house piping is within the wall? If yes, possible not to overlay wall ties.
Brand of it? Try to get quartz. highly heat and scratch resistance.
If you get solid door the price is around the same.
Edited by Devilaz
I think is reasonable but you should compare more.
Your painting is definitely cheaper than mine.
I was quoted S$1,300 for a new 4-room BTO.
I am still comparing prices.
