Hailey Lim
J&h Home @ Woodlands Dew
Thanks mate. I am still deciding between electric storage tank or gas heater
i always thot that storage heaters will take a much longer time (5min) to heat up ? whereby before you bath, turn on the switch for 5min for water to "boil".
i bought gas heater for convenient, auto on and off. whereby when there is water movement, it will on, and off when no water movement. i guess it works like normal instant heater, just that maybe because from the gas heater to the shower head, there is some distance, thus you need to drain these water first before you will get the heated water.
i will confirm once i use it.. cheers!
Gas heater takes approx. 30 seconds to 1 minute heat up the water.
Do u need to let the water run while u wait?
Didn't realise you bought both 3 and 2-blades. Any diff btw the 2?
seems like 2 blades breeze is stronger.. but then maybe also because we placed it in MBR which is smaller than living room.
  • Like 1
The smaller room make a difference. More blades and longer length should be stronger.
  • Like 1
Yup! That's what we think too!
Sharing our Tabao loots (Part 2).
Our reno journey is more or less completed except for some defects rectification.
20140704_232847_mr1404487779115_mh140448
  • Like 1
