claypot
Tam-Pines Head-Dee-Bee 3-Rm Re-Newal Tea-Blog
LED Ceiling Light at Study Room (forgot to test the LED strip light below the top-hung study cabinet):
Edited by claypot
The long strip of light in your kitchen is from where and how much does it cost ? Also is it LED ?
(*By the way still waiting for your invitation :bleah: )
Edited by Songz
It's a strip of LED that is mounted inside a hole that the carpenters will make underneath the kitchen cabinet. The electrician will then paste the LED strip into the hole and connect to the LED driver and then the LED driver is connected to the electrical wires.
busy now leh. probably mid-march then renovations complete and have time.
Edited by claypot
Finally, the Downlights which is tunable between warm and cool light:
warm light at the maximum brightness:
warm light at the minimum brightness (dimmed to the max):
This lamp is nice. is it from philip ? what model ?
not from philips. its from one of the lighting shops at Paya Lebar area. i bought it in Jan 2014 (before CNY). The display set was the last piece so I bought the display set at 20% discount. Didn't want to order and wait for new stock as i was told the earliest new stock will arrive is March, which is too long.
by the way, this light is remote controlled (so wall switch is not required) and can change from warm to cool light. It is also dimmable but i find that the dimming granularity is not good; the dimmest level is still bright.
its a good buy !
nice use of lights claypot! I like. haha. Can create different moods whenever you need to.
Renovation proceeding very well. :good:
Today is the eve of CNY, and also the start of CNY break for everyone. Electrical wiring was pre-laid and trunking installed over the past 2 days.
I am very interested on how you run you AC pipe. Did you conseal the trucking? Some pictures will greatly help. Thanks.
