The Pigeon Hole In Jurong East
My stainless steel shower water drain. (I hope is 100% stainless steel)
Will update pictures after my installation.
Hi
normally this is to buy yourself or is included in the plumping work ?
  • Replies 298
  • Views 71.8k
  • SOLVINDEN Solar-Powered Buoy Lamp by Johanna Jelinek A gadget from my wife. She told me this is the last white one in IKEA Singapore. Now we can illuminate the kitchen path without turning on the lig
  • Boconcept ottawa table. (Purchased before a reno contract.) We entertain a lot therefore we believe the dining area is more important when the living area. An extendable dining table will be ideal for
  • Me too. No top cabinet too. Let's see who will have an uglier kitchen.
Hi normally this is to buy yourself or is included in the plumping work ?
Should be included. However I paid for my own upgrade.
Now you see it.
Soon you don't. (Using calcium silicate board due to possible moisture)
Edited by marcel
This is a picture how we reduce the number of visible piping in the bathrooms.
Run all pipes in the common bath room.
Punch 2 pipes (1 Hot & 1 Cold) through the common wall into the master bath room.
Conceal all the pipes behind a calcium silicate wall. (Instead of 2x conceal for both common and master.)
A similar idea to soloqueen’s http://www.renotalk.com/forum/topic/63885-transformation-in-telok-blangah-drive/page-2
Edited by marcel
Should we leave or remove all the exposure PTFE tape?
Edited by marcel
Here you go. This is the best I can do. (No way to move further. Else I have to knock a hole into the neighbour’s place.)
Thanks so much for the picture.
It looks quite nice (kind of raw look)
I will suggest to leave as you need to use it in the future.
PTEF tap is the one that protrude out for the water right ?
(*juz my 2 cents worth)
Thank you. For extra protection I will add a glass door rubber seal strip.
More importantly, the door must be installed above the sloping part. If that is done, there is no need for the rubber seal. If not supervised, many contractors will install directly above the joint. In that case, even with a rubber seal, it will not keep out water totally.
I never remove any of these tape. In the process of removal, you might accidentally cause the tap to leak.
Day 29
We are moving to the final stage of boxing up all the visible piping. I reckon we should finish everything by end of this week.
MASTER BEDROOM
Conceal the AC Piping
Edited by marcel
I was in BKK shopping! (Actually I was there for 2 day business trip. Skipped lunch and rushed to the biggest DIY Shop BKK)
This place is reno heaven. You can find everything under one roof. CHEAPER THAN SINGAPORE.
My 304 stainless steel purchase.
1x VRH Faucet for my washer
2x VRH Robe hook
2x VRH Basin water trap
4x VRH Toilet spray (2x as spares)
Total: SGD150
5DF000E8-2D02-4DF3-8DE4-DC51B72924B6_zps
D97FC2C2-BE9F-4390-A5DC-718FC7E36AD3_zps
Not forgetting my Zebra head water container
8ADB2BA3-9C7A-4205-A0EF-E96CDA7DDD9D_zps
Edited by marcel
If you are going for a light, uniform look, go for the white lilac. The main difference between the two colors is that white lilac is of a warmer shade (yellowish), while special touch is a cool shade (bluish). IMO, juxtaposing special touch and the warm flooring will look "off".
MASTER BATHROOM
Accordingly to the schedule. We should be installing all the faucets this Saturday.
AFTER
1912082_838335699515305_2072053210_o_zps
1654973_838336179515257_1297736562_o_zps
BEFORE
918CFF76-E871-442F-A457-0E7131E75A85_zps
PROCESS
Edited by marcel
COMMON BATHROOM
I have standby my SLR for this weekend photo shot.
AFTER (Not complete.)
1966295_838340516181490_2013375902_o_zps
Edited by marcel
White lilac is too near the color of your flooring and thus don have the contrast as much as the Special Touch.
I will go for the Special touch in this case (*Note I am not really good in color combination)
*Juz my 2 cents worth ...
Thanks Songz and razzberrie. By this weekend, you will know which color I select.
