ddl1976
Replacing 2 Homogeneous Tiles
Hi all,
I just recently moved into my newly renovated resale flat for about a month and had some issues with a few floor tiles.
One of them was caused by myself. I wanted to clean some paint stains in between the grout and had indirectly cleaned a small portion of the homogenous tile with rubbing alcohol and the green cleaning pad.
Thereafter that portion (size of a slightly larger fifty cent coin) of that tile had lost its glossiness.
For the second tile, there is a small hole which I am not sure what caused it.
It really feels sad when I see those two tiles especially the first tile..
I am contemplating to replaced that two tiles for $150 but my family advised me not to since it is a small damage.
They mentioned that the replacement may cause the nearby tiles to break and if not done properly the replaced tiles may pop out a few months later..
Have any of you guys did any thing like that before? Is it true?
Not sure if I should still proceed with the replacement so would like to seek your opinions.. Thanks
Hi all,
Have you gotten it fixed?
We replace two tiles as these tiles' edge was a bit wrong doing, the worker, from China, actually knock off the near by four pc and replace the two. total I think he replaced 6 pcs This workmanship is perfect only that the replacement tile is a bit darker then the original as these are the second batch of the shipment.
I think the replacement for these tile is not as simple as a layman think, actually I saw the worker had grind a bit smaller to place the tiles and the workmanship really play a part.
