lyz77
How To Convert Incandescent/ Halogen Lamp To Led?
Hi all,
I am an end-user and not an expert in electronic stuff. I have the plan of replacing my incandescent/ halogen lamp to LED but I understand that my current dimmers is not compatible with dimming of LED. I am wondering if there is a workaround or solution where I can make use of my current dimmer to control LED dimming?
Appreciate any advise on this.
Thanks in advance!
helped a friend to checked on this topic last year.
here is my summary of finding :
While there are LED bulbs out there which will fit a halogen holder, it is highly recommended to change the entire setup.
Simple logic being that the halogen uses higher wattage and fitting the LED means stepping down the power > a potential failure point.
