Acewind 0 Report post Posted November 24, 2013 Anyone can recommend me where can I get someone to paste the laminates (formacia) I bought onto a customised size piece of plywood?Thabks you Share this post Link to post Share on other sites
SKYJUICE123 0 Report post Posted December 2, 2013 (edited) It is not difficult to paste Formica to plywoods.. you will need some tools such as formica cutter, D-clamps and some timber strips.. go buy a can of cement glue and a paint brush and some sand paper. Cut the plywood and formica to size. Clean the plywood and formica and then apply the cement glue evenly on both surfaces using the paint brush. Let dry the glue until it won't stick fingers, then stick both surfaces together. Using timber strips and D-clamp to apply pressure for good adhesion.. Here is one example..http://www.wikihow.com/Put-Laminate-on-a-Counter-TopIf you want someone to do it for you, go to any wood working firm and get help.. plenty in Eunos and Ubi area Edited December 2, 2013 by SKYJUICE123 Share this post Link to post Share on other sites
monkeykongkong 0 Report post Posted July 25, 2014 I believe this company sells Formica glue (contact adhesive), you can check out their website www.maxconenterprise.com they are a plywood and timber supplier so i believe their glue is suitable for such use cheers Share this post Link to post Share on other sites
StyloMylo 27 Report post Posted November 19, 2014 you can it yourself, very one Share this post Link to post Share on other sites
