busybody1
How Much Space Is Need Around The Fridge ?
Hi bros ,How much space is need around the fridge ? I'm getting new fridge .My fridge base is 78cm x 75cm .I thought of getting Panasonic fridge which is 77cm x 74.5cm .so the left side gap is only 1cm(left side) . is the 1cm gap enough ? this is the picture of my kitchen .
Brand - Panasonic
Model - NR-BY602XSSG
Product Width (cm): 77.5
Product Depth (cm): 74.5
Product Height (cm): 184.6
I think should be enough as long as there is airflow to faciliate heat transfer. My own fridge has been running for about two three years in abt the same condition and still no problem.
Better to check Panasonic manual for minimum gap needed, gaps are very important to a fridge, your fridge will need to work only harder if it cannot efficiently radiate the heat away, if sway sway if the compressor really burn out, the serviceman might tell you to fly kite because you did not install the fridge properly.
